Results 1 to 15 of 16
Thread: Welding radiator support panel...
    Junior Member 1st year Apprentice ArJay's Avatar
    Default Welding radiator support panel...
    Hey guys.
    Just wondering if anyone could answer a couple questions for me. Picked up a AE92 SX Seca just recently that has had a bit of a front end bingle and will have to have the rad support panel replaced. Just went and got a nose cut from a wrecker....
    My question is...is it something I could do myself or am I better off taking it to a panel beater? I'm a bit of a novice with a MIG but can do basic stuff...
    Rory
    Keep it Low and Slow
    AusZoku
    Junior Member Domestic Engineer Alex's Avatar
    Aug 2006
    vic
    Default Re: Welding radiator support panel...
    There is a fair amount of drilling required to "unpick" all the welds to remove your rad support from the nose cut, welding will be the easy part, I suggest you give it a go it is an easy job, if you need step by step info let me know.
    Thanks MH. Good call....
    So when the "new' one goes back in is it best to just spot weld it similar to the existing one? Is there anything to look out for?
    Cheers for the help...
    R
    AusZoku
    Aug 2006
    vic
    you will need to use a couple of srews or tack welds to sort out your final position of the rad panel, then trial fit guards, bonnet, headlights, grill and bumperbar, then when satisfied, take all your bolt-on panels etc off again, weld it up
    As for getting your old rad support off the car, just use a grinder rather than a drill and grind through the spot welds on the rad support side, it wont matter if it's messy coz you'll be throwing the old rad support out anyway, it is much faster than drilling
    Make sure you take your time with your new/frontcut rad support drilling then chiseling the spot welds undone it can be a pain in the arse but it's worth it
    Great info. Thanks MH...will really save me time and $.
    When you're talking about drilling out the welds on the replacement panel, do you have to use any special tool or just get stuck into it with a metal bit. Obviously you have to make sure you don't penetrate the panel?
    R
    AusZoku
    Aug 2006
    vic
    Start with 1/8 as a guide hole then follow through with a drill bit anything bigger or the same size as the spot welds, you can go all the way through both panels with unpicking the frontcut/new rad as the bigger hole will be filled with mig,
    As for the old rad attached to your car, use a grinder i said previously, but if you need to drill some hard to get welds, only counter sink them with the big drill bit so you dont have to try and fill massive holes in both panels
    Hoping this is all making sense
    Yep making total sense. Thanks heaps for the help mate...much appreciated.
    Will attack it on the weekend. Will post up how I go.
    Thanks again
    Rory
    AusZoku
    FWIW you can also buy spotweld drill bits at some good tool shops, last one I got was about $20, they just go through the top sheet of metal so you're not left with a whole hole in your car to fill with the MIG
    Ok cheers JP. Perhaps might look into that...
    R
    AusZoku
    Western Aus
    Quote Originally Posted by Mike Hunt
    also, use a metal punch to punch a dent in the centre of the spot weld, helps center your pilot hole.
    Elmo.
    Thanks Elmo....more handy hints. See, this is the sort of stuff I had no idea about...
    Cheers mate
    R
    AusZoku
    Update...
    Did the front end of the AE92 over the weekend. Cheers for the pointers folks, especially MH. Really helped out in knowing how to go about it.
    Like you said MH, was a fairly easyish job in the end. The main pain in the arse was unpicking the welds and aligning the panels...
    Needs a bit of cosmetic shit done like painting the ricer bonnet (couldn't find a white one) but otherwise is done...
    Rory
    Before
    During
    After
    AusZoku
    Aug 2006
    vic
    Nice work, it was worth having a shot at it yourself was'nt it!
    Sure was mate! Cheers again for the encouragement....was well worth doing
    AusZoku
    Western Aus
    looks awesome mate!
    top work!
    Elmo.
  1. KE70 Panel Van Dash
    By Gleno28 in forum Tech and Conversions
    Last Post: 23-04-2010, 12:21 PM
  2. mig welding car panels
    By styler in forum Tech and Conversions
    Last Post: 11-08-2009, 03:45 PM
  3. Replacement of Radiator Support Panel
    By twentyEight in forum Tech and Conversions
    Last Post: 13-10-2006, 11:17 AM
