Once the car is at normal operating temps and I turn it off for a few minutes. It starts without a problem but if it stands for a bit longer, I have to crank it for about 5 seconds.
I have read somewhere else that the FPR is to blame and once it was replaced by an aftermarket unit, the problem was fixed.
Could I just replace the old one with a new unit from Toyota instead of an aftermarket unit?
Any tips and help greatly appreciated.
AE93 SX - Thrasher 20V
JZX100 Chaser - Daily 1J lovin
yeah, if you want to replace the standard one then thats no worries.
some cars also have a no return valve in the fuel pump that screws up, allowing the fuel to run back into the tank. causing a little longer start time cause the pump has to prime the system first.
Originally Posted by The Witzl
