Page 1 of 3 123 LastLast
Results 1 to 15 of 31
Thread: DIY fuel and brake lines
    Default DIY fuel and brake lines
    I did a quick search but didn't find much on the topic. Has anyone here made their own fuel/brake hard lines? I'm considering this and would appreciate any hints or suggestions, including "don't even bother" if appropriate.
    In my case I had to remove the three fuel lines and one brake line running along the floorpan of my Supra, because they were routed along the transmission tunnel which was recently hacked up and re-shaped. So now I need four new lines which follow a different path, some with threaded connections (brake line and pressurised fuel line) and some with plain flared ends with hoses pushed over (fuel return and breather lines). Is it feasible/practical to do this yourself after purchasing the appropriate tools, or am I better off forking out the $$$ to have a pro do it (remembering the car is by no means mobile)? And if going DIY what tools would I need to do the job properly?
    Any input appreciated.
    Default Re: DIY fuel and brake lines
    Somewhat the same, I have rebent a hard clutch line and turbo oil lines a significant amount to fit another car / turbo without drama.
    I believe that the tube itself is quite cheap.
    You'll need a bender which may cost an amount.
    As for fittings, you can hack your old lines up for the fittings, either buy the flaring tool (should be pretty reasonable) or get someone else to do the flaring.
    I'd suggest getting costs for the pipe bender, pipe and flaring tool and see how that compares to a price for one of the mobile people
    Another thing to think about is if you have the motivation and patience to make the lines, might make the mobile guy a reasonable option if it isn't something that you think you will enjoy
    Get your self a bender and double flare tool, fittings are worth very little
    The tube is very cheap,
    I have done quite a few and its not a hard job just time consuming to get them spot on.
    Western Aus
    id sugest leaving the front brake obviously to the experts, but seeing as your not doing that, its all good.
    while i was at kennards hire the other month getting the trailer for my halfcut, i noticed a range of hydraulic pipe benders they had, and im pretty sure they even had some tools for the smaller stuff.
    sure beats that $22 bender avaliable at supacheap...
    Elmo.
    I already have a pipe bender I picked up at Supercheap, and as you would expect it was super cheap but looks a bit crappy. Hopefully it's good enough to do the job though. They had flaring tools as well but they looked too crappy so I'm going to investigate the price of decent ones at a proper tool shop. I guess I should pick up a pipe-cutting tool as well, using a hacksaw could be a bit of a pain when you're dealing with 3 metres of tube bent into strange shapes.
    Buying the tools doesn't worry me though, I guess what I need to know is can I acheive a satisfactory result with no prior experience and no-one to show me how it's done?
    I've already priced the tube (dead cheap) and the fittings can be recycled from my old lines so that's not a problem.
    has no Toyota anymore :( Conversion King tooch's Avatar
    Have a read of this, should give you some tips
    http://www.hoppers.com.au/street4.htm
    The flairing tool will make all the difference. We have 2-3 different ones here at work.
    DO NOT USE the hand held ones. They are ever so cheap and flimsy, and 95% of the time, the flair is shithouse. The best ones are the bench/vice mounted.
    They do however cost a mint.
    If you dont want to buy one, make up all the lines and goto a brake place and get them to do all the flair work.
    Daily: '06 Liberty 3.0R specB
    Junior Member Grease Monkey DoctorDubb's Avatar
    May 2006
    Im looking into it myself as im just about to do my clutch line for my ra28.
    http://forums.toymods.org.au/index.p...t=0#msg_679162
    There is concern about copper being a weaker (though more easier alternative) thats more likely to break and isnt ADR approved.
    Another post that actually states that copper line for fuel line will deterate and suggests either alloy or steel pipe
    http://forums.toymods.org.au/index.p...t=0#msg_109296
    'Bundy tube' seems to be the nickname of the steel line.
    Some people bend with a socket or buy a cheap bending tool.
    Double flaring seems to be the best way of going but the tool is awlfully expensive for just one job so just take the completed pipe to get double flared for a few $$ at your local brake place.
    And where did you get it priced from norbie? as i got quoted $12 a metre from local repco
    For sure is my opinion!
    Might take a bit of patience is all
    I bend up brake line and oil suctions for work its not that hard. The worst part is marking the bend in the right place. I would suggest using a quality flaring tool wich allows you to double flare and make sure you give yourself enough tube sticking out of the flaring boss so is gets a good mushroom for when you go and roll the second flare.
    Alex
    RA28 Turbo 18RG
    RT104 - spare toy
    BF II XR8
    On a related note, can anyone see a problem with using rubber fuel line instead of bundy tube for the rear section of the lines? The problem with the MA61 is the three fuel lines pass through a narrow gap between the floorpan and the rear subframe, and there are lots of bends in the tube around that area which means it's impossible to remove the lines with the subframe in place without basically destroying them (which I did). Installing new lines will be equally difficult/impossible, so I can either (a) remove the rear subframe/suspension/diff etc or (b) run hard lines up to the subframe and rubber lines from there to the fuel tank. Obviously option (b) is FAR easier, can anyone think of a reason why it would be bad?
    Western Aus
    whats new pussycat woahhhhhhhhh woahhhhhhhh woah woah woah ehehehe.
    i cant think of a reason, we did this on a mates silvia (and 4AGE converted KE70), obviously not as hardcore as your car, but as long as theres some form of stopper on each side of the metal line (flare, lump of weld, lip etc) to stop it sliding off, it should be fine.
    Elmo.
    In the case of the pressurised fuel line I'll be using threaded fittings on both ends, same as the original setup. In fact the original setup joined the fuel tank to the hard lines with short sections of rubber hose, so all I'm really doing is making the rubber bits longer. So now I think about it I'm not changing anything and there's nothing to worry about!
    I am about to do the flaring of my brake lines also. I am fitting a line locker so I had to chop the lines, get 2 fittings to suit the line and the line lock and now have to get them flared.
    I was going to get mechanic to do it but my car is also immobile so I changed my mind. I already had pipe cutter and bender just needed the flaring tool. I picked one up from ebay for $40 for a double flare. Obviously not industrial quality but if it lasts me more than these 3 flares then it is money well spent
    Glenfords wanted $130 for a single flaring tool and about $200 for a double flare IIRC.
    I am also doing one other brake fitting as it was absolutely stripped. I don't know how they strip when you are using the correctly sized brake line spanners but it did.
    QUICKEST 1JZ'S IN OZ
    we bought a double flaring tool for use at work, cost around the $150 mark from memory. until we got that i was making do with a single flare but its not as good.
    also i use copper tube for brakes and fuel, alot of people poo poo the idea but im yet to have problems, have had one section of copper brake line on the sprinter for about 5 years now so far so good.
  1. Electric fuel pump stopped working.... HELP!
    Last Post: 18-09-2007, 07:04 PM
  2. MA70 --> JZA70 Conversion
  3. Aftermarket engine management and injectors
    Last Post: 14-05-2006, 01:05 PM
  4. Rear Disc Conversion for FWD Cars
    By wagonist in forum FAQ
