Results 1 to 15 of 17
Thread: Help please - 1HZ landcruiser overheating!
    Default Help please - 1HZ landcruiser overheating!
    Hi all
    My uncle has an issue with his hzj75 landcruiser overheating. The thing is running great, has a new radiator, new injector pump, water pump etc etc but it just overheats when you start to work it hard.
    For example, towing a car trailer up a hill last night it almost boiled - and the temp goes up almost instantly! But then as soon as its not working as hard, it comes back down just as quick!
    its been happening for a while now and is starting to become a nuisance...
    Is there any problems i should be pointing the finger at? timing perhaps?
    Blake
    THE OFFICIAL TOYMODS BOGAN
    MA61 - sunroof., 7MGTE, 4.11 lsd, w58
    MA61 - Built 2JZ, 9" diff, big brakes -1st car + the toy
    LN167 - dual cab fourbie, gu patrol chassis + suspension/ driveline, built 1.5jz
    perth
    Default Re: Help please - 1HZ landcruiser overheating!
    thermostate ?
    being diesel its has no ignition timing only fuel timing.
    I'd have thought something relating to the thermostat not opening fully with the symptoms you describe, i'd replace it just in case if you haven't already, cheap insurance
    wa
    possibly a crack in the head
    around the precomp chamber
    they do this quite a bit
    yeah i was thinking either cracked head or thermostat - for his sake i hope it isnt a cracked head as 1HZ aint a cheap motor to fix...
    wa
    id definately try thermostat first though(cheaper than head)
    turns out it has a new thermostat - so i guess its not looking good for him...
    engine been freshened up lately?....or hasnt been given a good work out since he got it or something?
    Junior Member Grease Monkey Cruiser97_80's Avatar
    Tasmania
    Does the fan get louder when it gets warm, because it should.
    Fairly common problem with the viscous coupling fans on 75's.
    2 ways of fixing 1. buy a new coupling, 2. You can buy the special oil that goes into the fan coupling from toyota, 1 bottle is 10ml or something like that just add 1 bottle 2 what ever is left in the coupling. This is a fair bit cheaper but does not always work. If you want extra cooling power add 2 bottles, but this will make the fan work hard all the time will make it sound like an aeroplane taking off when giving it a bit.
    1990 ST185 GT4 3SGTE
    1991 ST184 SX 3SGTE
    1991 SW20 GT 3SGTE
    1998 ST215 GTT 3SGTE
    2008 VDJ200 Sahara
    nah it runs a huge ass commodore electric fan, which is doing more than its job at cooling the motor down. its also got a 10" fan on the front to aid...
    Quote Originally Posted by BeRad
    nah this has been happening and we've been trying to fix it for a year...
    Junior Member Grease Monkey off-road's Avatar
    NT
    Sounds like everything has been done except head. Symptoms are same as blocked radiater (on the outside fins-they get full of grass seeds up here.) but if radiater is new its probably not that.
    Quote Originally Posted by off-road
    nah brand new 4 core radiator a week ago.
    How can i test to see if it is a crack in the head? Will a compression test show it or do i need to take the head off?
    Junior Member Backyard Mechanic lojik's Avatar
    If head is cracked then you could be getting combustion gases being pushed into the water.
    A shop can put a meter over/in your radiator filler and test whether combustion gases are present in the coolant mix.
    Quote Originally Posted by lojik
    will a compression test show it tho? i have a test kit of my own therefore i dont need to pay a mechanic thats all...
  1. 4a-c Ae82 Overheating Problem!!!
    By nos4ag in forum Tech and Conversions
    Last Post: 07-11-2008, 08:27 PM
  2. Cooling Systems - Overheating Problems.
  3. Overheating Phantom
    By kwayzivietnamese in forum Tech and Conversions
    Last Post: 06-04-2006, 10:55 PM
  4. using landcruiser front diffs for celica rear diff conversions.
    Last Post: 09-02-2006, 06:55 PM
