im a bit lost as to what you are struggling with?
is it just the handle you are removing? or all the roddery inside the door aswell.
to remove the handle. undo the bolts that hold it in. then where the rod runs to it you will see little plastic clips holding it. get the clip of then it can rotate (memory is fuzzy, but u get the clip off then the rod will come out easy peasy.)
and getting them back in is a reversal. was quite simple from memory. and i was only 16 when i last did them
the rods do come out of the doors from memory.
you just undo all the clips then fiddle it around and she will come out.
everything in the ke70 doors is fiddly, but its not particularly difficult if you have a close look.
hope this has helped. if not grab some pics of the bit u are strugglin with and i will try to help...
