For aw11 gze, although I dare say map gze will be the same,Originally Posted by madrolla68
correct me if im wrong.
Shim clearance when cold
Intake -- 0.15mm-0.25mm
Exhaust -- 0.20mm-0.30mm
Head Bolt
1. 29Nm In sequence
2. rotate 90 deg In sequence
3. rotate 90 deg In sequence
Conrods (12 sided nut)
1. 39Nm
2. rotate 90 deg
Conrods (Hexagon nut)
1. 49Nm
Yes the Cas has to be timed, Very similar to a dizzy as you said.
