Results 1 to 7 of 7
Thread: Very short clutch master cylinder
    Default Very short clutch master cylinder
    Hello all, i'm chasing a very very short clutch master cylinder. I recall a thread about this before but cannot find it , maybe i am imagining it.
    Anyhow.. Does anyone know of a very short clutch master ? I'm talking like 40mm from the mounting face to the end external end of it. Can protrude into the cabin a reasonable distance if required.
    Joel
    1996 FZJ80 Landcruiser.
    Email : [email protected]
    Default Re: Very short clutch master cylinder
    Far out man, 40mm.... Even the cut down AE71 item that im using is 70mm long....
    Maybe look at the custom manufacturers, like Wilwood.
    Junior Member Grease Monkey styler's Avatar
    Jun 2006
    maybe mount the shortest one you can find inside the cabin, ie use a spacer and have the flange inside the cabin with the bolts through the spacer and back on to the firewall?
    Styler, that is definately an option and probably going to have to go down that path.
    Just thought might be lucky and find some freaky short cylinder.
    I heard a suzuki baleno one is short but cant find any pics.. Might have to see if any brake shops have one in stock to look at.
    I think AP might make a racing master cylinder that's pretty short.
    Check with Meridian Motorsport or the like.
    www.billzilla.org
    Toymods founding member #3
    theres one hiding under the bar here.. hard to see..
    http://www.suzitech.com/pics/convers...0turbo%201.jpg
    heres a pic of th ebooster
    http://www.suzitech.com/pics/product...%20booster.jpg
    Have you thought about using a reverse swing pedal (like a Tarago or Wilwood)? this will allow the entire master to be mounted inside with just a remote reservoir.
  1. TA22 Brake Master Cylinder options...
    Last Post: 09-04-2022, 06:31 PM
  2. JZA70 Master Cylinder in RA23 - Advice Please
    By fuzz! in forum Tech and Conversions
    Last Post: 26-02-2006, 05:08 PM
