Results 46 to 50 of 50
Thread: Light Vs heavy pistons (ie: ACL specs)
  1. #46
    New Zealand
    Default Re: Light Vs heavy pistons (ie: ACL specs)
    tooooo many numbers....
    Anyway
    Silvertop Piston Pins = 99 grams
    Blacktop Piston Pins = 85 grams
  2. #47
    Victoria, Mt Macedon
    -GT- it accelerates quicker because the car is essentially lighter (ok, the internals have less rotational inertia and weight to be precise). Less weight means more acceleration for a given force.
    You are making better use of the available power.
    Interesting to note from OCs calcs that the whole "spin up faster story" is fairly negligible. Taking the average velocity and squaring it isn't the best, it should really be the average of the velocity squared. But that'd take some interesting integration. I was bored (on a plane) the other day and tried to work out the energy of crank, rods and pistons. I gave up after an hour.
    Sam - From memory the loads on the crank will be related to the square of the speed, and directly to the weight. So if you change pistons and rods to something half the weight, you should be able to rev it to 1.41 times the previous limit (all other things being equal).
    Hen
  3. #48
    Normally Aspirated Domestic Engineer RT104GT's Avatar
    Default Re: acl 20v pistons
    Weight, reciprocating weight and strength factors, material from which piston is forged, type or rings, type of pistons design.
    Ever thought of offering services to a racing engine guy?
    If it was that easy they would have thought about it already.
    Early 9RG and 8RG and 18RG pistons used to nick/nip up occasionally and needed replacing.
    Usually when you revved the drap out of the engine.
    Incidentally the original 88220 heads and 9.7 pistons in the original 18RG Toyota went like the clappers but never lasted the distance.
    You could sustain 7000 rpm in most gears.
    There are thousands of late model engines with 88235's 250's heads and fitted with lower comp engines but the original high performers are dodo's. now.
    So you might design an engine that spins up well but if it has to be stripped down every time you run it what is the point?
    Like I said go work for TRD if you think you have the answers.
  4. #49
    New Zealand
    does a car with a lighter flywheel have more horsepower?
    same theory
    please, no more PMs!
  5. #50
    Quote Originally Posted by Mr Revhead
    same theory
    Accelerates quicker but has less torque?
    Thus torque converter (a.k.a. liquid flywheel) in slush box which has only a flex plate.
    we also experiment with varous viscosities in autos to get faster spool up.
  1. Building a 3TGTE turbo motor
    By TIMTAMS in forum Tech and Conversions
    Last Post: 03-05-2008, 10:28 AM
  2. Higher comp pistons for 4agze ?
    Last Post: 15-04-2007, 04:48 PM
  3. comparing 2T and 2T-G standard pistons
    By w810sc in forum Tech and Conversions
    Last Post: 02-01-2007, 05:28 PM
  4. Pistons - Cast vs Forged vs Hypereutectic
    Last Post: 21-11-2006, 02:04 PM
  5. wiseco pistons for 2tgte
    By cooter in forum Tech and Conversions
    Last Post: 02-10-2006, 04:26 PM
