Results 1 to 8 of 8
Thread: Side Feed Injector Data Chart...
    Default Side Feed Injector Data Chart...
    While trying to find 1JZ & 2JZ standard injector capacity and lag time i came across this link...
    http://www.williams.co.tt/s15/inj_side-en.htm
    I'm wondering how accurate the information is? (2JZ injector = 430cc??)
    What do you think?
    JZA70|R / 12.45 @ 111 mph.
    Turboholic Grease Monkey VeeP's Avatar
    Default Re: Side Feed Injector Data Chart...
    hey now that uv brought it up. . .
    is there any difference between a side feed and top feed injector apart from the obvious?
    '88 Soarer GT-L
    '90 Supra Aerotop
    That is saying that the 1jz and JDM 2jz injectors outflow their rating but the US 2jz ones underflow assuming 3 bar fuel pressure even though it is actually 42psi.
    That could be why some people believe some big power figures can be obtained with the 440's and others believe 550's aren't enough?
    QUICKEST 1JZ'S IN OZ
    Junior Member 1st year Apprentice Mazman's Avatar
    Quote Originally Posted by VeeP
    side feed injectors are also cooled by being inside the rail/in the fuel
    so are JDM 2JZ injectors 430 or 440cc?
    Feb 2007
    Timaru
    Quote Originally Posted by JZA70 R
    dont know, but at 45 psi they flowed 500cc,
    and the supposed 550's we replaced them with from USA spec one's flowed 600cc at 45psi.
    - KE70 Corolla Dx -
    - 500hp+ 7AGTE 20V turbo -
    - MRS/Hayabusa turbo **sold**
    Junior Member Backyard Mechanic lojik's Avatar
    Are side feed injectors more likely to introduce pressure pulses in the rail?
    Feb 2007
    Timaru
    Quote Originally Posted by lojik
    Not too sure, but have heard that with high flow pumps and injectors that you can get pressure drop across the rail,
    but never seen it or tested for it so cannot say.
    Maybe internet rumours.
    - KE70 Corolla Dx -
  1. side feed injector query
    By terryo in forum Tech and Conversions
    Last Post: 25-03-2007, 06:51 PM
  2. side feed fuel rail injector spacing
    By -==L=a=N=c=E==- in forum Tech and Conversions
    Last Post: 21-06-2006, 08:10 PM
