Page 8 of 36 FirstFirst ... 67891018 ... LastLast
Results 106 to 120 of 531
Thread: Toyota's Interchangable Oddities.... (TIO#)
  1. #106
    Default Re: Toyota's Interchangable Oddities.... (TIO#)
    Quote Originally Posted by -==L=a=N=c=E==-
    BTW: who said the 4age cams fit the 3sgte head? more info please!!!
    I was told that 4AGE 16V cams fit into a 3SGTE head by a reasonably reputable aftermarket cam grinder.
    If someone wants to come around with a 4AG cam I can quickly sit it in my disassembled Gen2 head and see if it fits.
    Either that or someone can take one of my Gen2 cams and whack it in their 4AG head for testing if they want.
    /me looks towards Domasik!
    Edit: Now disproved.
  2. #107
    Rosewood
    this is the tech section - keep on topic
  3. #108
    OGT-630 Grease Monkey rokusan's Avatar
    well theres all the usual stuff like 3sge block fits gte crank and head, 2s engine mounts boltup to ge block, 2j injectors fit gen 1 and two with 7m plugs (cheers soarer21) 165 crank takes f engine rearmain seal, ge rods same as gte, 141 corona flywheel fits 3y starter, 2s pulley fits 3sgte's, 2s p/s fits 3s block, ma61 fuel tank fits sa63, 2s sump almost bolts to 3s, exact fit requires 2s rearmain seal housing with the two extra bolt holes, 2y bellhousing and 2s oil pickup fit 3s's with help of diegrinder, lots of nissan-bitza-missin parts fit, as do various ford and gm items.
    Oh yea and 3sgte gen 1/2 turbo manifold fits a 5sfe! ..except one bolt hole but who's counting..
    SA63-3SGTE coupe driftpig
  4. #109
    Toymods Club Member Backyard Mechanic Big T's Avatar
    Quote Originally Posted by Toobs
    Toobs, I'll drop off a smallport cam tomorrow morning. If no-one's home i'll just put it in the mailbox or something.
    Eddie.
  5. #110
    Junior Member Grease Monkey Jonny Rochester's Avatar
    Tasmania
    All Corollas from KE30 to AE112 have the same brake and clutch pedal rubbers, also the same as many Diahatsu's, ZZT321 Celica, and ZZW30 MR2.
    ZZE122 plastic window winders are the same as AE86 (and most models inbetween) but different colours.
    AE86 interia light, same as late model duel cab HiLux, RZN165, RZN149...
    KE30,KE55,RA23,RA28 lower control arms all the same, same length.
  6. #111
    teq Grease Monkey
    California
    Quote Originally Posted by RAV-GT4
    A few odd-bits when comparing 4WD Toyota stuff...
    Adding my 2 cents...
    Limited Edition 4-Runner's come with larger front brake discs and different calipers - 11" rotors.
    These same calipers and rotors bolt right onto any Tacoma/Hilux 4x4 (factory caliper mounts) as an easy brake upgrade (but do require 16" rims to clear)
    Andrew
  7. #112
    Rosewood
    M series engines fit into a 22R(E) engined car using 6M mounts and engine mounts. Using 7MGE bellhousing.
    W series gearbox and G series are interchangeable.
    EDIT: My apologise, big typo on my part. Was thinking of something totally different.
  8. #113
    Edited due to above edit.
  9. #114
    Penrith BC
    edited because ^^^^ he edited and the other guy too
    ../delete/ban
    tech moderator
  10. #115
    AE86 Tuning Life Backyard Mechanic Garth AE86's Avatar
    Sydney NSW
    Quote Originally Posted by Steve-AE86
    16v 4age bucket/shims are interchangeable with 2nz-fe(echo) buckets, therefore allowing higher revability in the 4age, by not flicking out shims with big cams, etc..
    i'm dying to do this...i wish someone would give me a 4age to do it to
    the ae92 heads are shim under anyhow are they not?
    only the original bigport engine has the shim over style buckets.
    ive been told the valvetrain kit from toda is just toyota kit with toda springs.
    dont know of the accuracy of this though.
    Garth - 100% AE86 Addict
    AE86 - Levin & Trueno - The Legends Live On!
    'AE86' - Toyota Sprinter Trueno GTV
    "It's not a street car if you can't drive it on the street. The car has to be safe and fast on any road condition" - Keiichi Tsuchiya
  11. #116
    Quote Originally Posted by ae86drift
    Nah dude, the smallports are also over-bucket shims. I used a set of smallport shims on my bigport head when i was short a couple.
    Eddie.
    4agte finally completed. 234rwkw @ 8125rpm. Tis fun
  12. #117
    Sydney NSW
    good to know! thanks!
  13. #118
    Rosewood
    Elaborate on this?
    M mounts will not bolt to a JZ, and nor will an M bellhousing.
    Quote Originally Posted by ed_jza80
    wtf??!! - clarification or deletion, those are the options
    Sorry guys, typo, was thinking something else entirely.
    The rest is true though (using M series engine) as seems to be a popular mod when dropping M series engines into hilux's and the like.
  14. #119
    Quote Originally Posted by Big T
    Eddie.
    Thanks BigT... I checked and the 4AG cam is about an inch shorter along and the spacing of the lobes is all wrong.
    Basically the cams are completely different.
    Myth Busted!
  15. #120
    Rosewood
    Myth Busted!
    Well, that was a bit of an anti climax. *goes back to shopping in the states*
