Just installed the windscreen wiper motor from a GA70- 88, into my ra28.
Looks diferent, smaller and neater but everything lines up.
i assume this means a large number of supra wiper motors will fit most older celicas?
tom
Have you got any measurements as I'm happy to measure them up against the various tierods I tried to fit...
tom
correct.... its a common upgrade that many do when they buy their GA70 frontcutOriginally Posted by thomasbl
Another interchangability or two....
UZS131 brake master cylinders fit RA2* boosters. Nice big fat 1" bore M.C. for all your braking needs
ST205 brake M.C. fits an AE71 booster. These move a LOOOOT of fluid!
Ta22 and RA23 Steering Columns are Nearly Interchangable, all you have to do is Replace the Base Plate, Not Hard for the Technically Minded. Then you have wipers and Headlight Controlls on the Column.
7MGE alternators also work on 4AGE's. Same plug too.
Here's some i know of..
- All V6 flywheels from 1988 to 2001 are the same.
- An E153 gearbox will bolt up to an early model 2VZFE
- The ST162 and SV21/VZV21 steering spline/offset is the same, hence they can share steering wheels.
A V6 flywheel will bolt up to an 8 bolt 3SFE, but is larger than the 3SFE stock flywheel by 0.5". Hence, a 3SFE/GE/GTE flywheel will not work on a V6. It will bolt up, but will slip.
Kind Regards,
Kurt.
1998 ER34 ニッサン スカイラインGT- T
This should then fit KE30 boosters too as the bolt pattern is the same.Originally Posted by The Witzl
Brad
Old Corollas never die...
My KE30
KE30 discs and calipers will fit onto KE20 wheel axles. straight swap.
although the stud pattern changes to 4 x 114.3, so you need some KE20 wheel hubs which bolt onto the 30 discs.
brake lines also fit no probs.
1JZGTE injectors are a direct fit into a 20v fuel rail. im unsure if the impeedence is different but they both worked without adjusting settings on the ECU.
probably belongs in the other thread (which i can't find right now), but daewoo cielo front indicator globe sockets are interchangable with the front bar sockets from the early model JZA80.
Anyone able to tell me if 4 pot Supra or Skyrice brakes are a direct bolt on for JZX90, and would I have to change from standard rotors to either brakes setup rotor?
hatchback: front seats from SA63 fit RA40. rear bottom seat fits no problem rear fold downs
fit in with minor mods to seats.
something else i thought of (if its of any use)
16R dizzy fits 18R and 20R
ta22 steering arms fit onto ra40 struts.
fiting ta22 springs into ra40 struts with ta22 spring hat and bolt in part(dunno what its called) bolts into a ke30 with some spring shortening.
Originally Posted by CrUZida
just to clarify one thing 2nz-fe bucket WILL not fit 4age and are not the same as the 1szfe buckets
They are bigger in dia.
