to clarify, there are at least 4 versions of K40 and 2 of the K50 in the corolla series..Originally Posted by 74ROLLA
3 different shifter positions (2 variants of the middle position. the KE20 vesrions sucks and most ppl break it the first time they try and pull the shifter out ), and for each shifter position the shift rods are different.... all except KE70 boxes have same rear mount.
however, shift rods can be swapped from box to box.. but at times, you may need to alter the position of the reverse switch.. (KE70 is at front of box, KE10 is in ext housing etc)
K50 extension housings between KE55 and KE70 are direct swap.
however, some things are not the same... notably the layshaft needle roller bearings come in at least 2 sizes... as do the bearings between the input and output shafts
i've had various combinations of al models stuck together at different times..
oh, and three different sets of speedo drives.. 5/19, 6/20 and 6/21... the 20 and 21 driven gears are interchangeable if the drive gear is 6 teeth, but not the 5 tooth.
5/19 came in KE10, and will fit in all the other K boxes
