This is the wiring diagram I used to wire MV shift box.
http://www.1jz-gte.us/documents/SubD...ZWiringECT.pdf
I take it you don't have a half cut?
Can you list what parts you have
engine:
gearbox: exact model would probably help ie. A3041LE
wiring: engine and trans
There isn't too many wires to sort out with these boxes. Basically, from what I can tell, Park is ignition switched power, then there are signals from R,N,D,2 & 1. Then there is another plug that has 4 wires. 1 I don't know what it is. 2 are for solenoid A and B which activate to change gears and the other is the lockup solenoid.
You may find this thread helpful. http://www.toymods.net/forums/showth...ht=autos+shift
I just thought you plug the normal plugs in that came with the front cut and give the whole thing power and wire into fuse box and alternator.
