For starters I'd clean all around where you think the oil leak is coming from, including any oil around your air-con unit. Then take it for a quick drive and then have a look for fresh oil. That's the best way to find the source of the leak.
Your wheels shouldn't turn at all when you're in neutral. Even if the clutch was slightly engaged (or even fully engaged for that matter) there should be no movement 'cos you got the gearbox in neutral.
seeyuzz
river
