Results 1 to 11 of 11
Thread: installing a tacho
    queensland
    Talking installing a tacho
    does any one know how to install a monster tacho in a 1991 toyota camry csi i have hooked up the power, ground, light and i dont know where to connect the other one.
    Default Re: installing a tacho
    to the monster Actually, it goes to the tacho output of your ECU. If you dont have a Tacho output on your ecu, then its the tacho output of your coil. Be careful doing this though, as you can interfere with the readings of your ECU.
    Low rep 1st year Apprentice
    victoria
    hey dude.. dont kno much bout camrys.. but the wire is for ya tach pulse if its carby put it on the - on ya coil.. an if it injected im not real sure were u can wire up 2.. but check the E.C.U. it shud hav a tacho reading wire there.. usally brown or green.. but not to sure bout camrys..
    High Rolla Grease Monkey sprinter_adam's Avatar
    u either put it to the ecu (dunno what pin) or to the coil
    Quote Originally Posted by eeeyan View Post
    wow this thread got off track fast i came back expecting in depth scientific and philosophical discussion and i find people takling about meals and wanking.
    awesome stuff. toymods FTW
    MA70 - the lupy bi@ch - proton wira - 5 colourd daily
    Lazy Member Grease Monkey Tats's Avatar
    Excercise a bit of caution if you're going to try and wire it up yourself. A friend-of-a-friend tried to wire up a tacho himself, didn't exactly know what he was doing. Fried the ECU. I think that taught him a lesson sufficiently.
    agreed with tats.
    The fact the camry is a CSi means that its injected, im assuming a 3SFE 2L. if you wire it directly to the coil, you may run into troubles. search the forums and google for pinouts of your ecu. Also, check your haynes or gregory manual(a must if you are going to DIY anything, and havent had extensive experience with multiple cars).
    Junior Member 1st year Apprentice turbo_gze's Avatar
    When i wired up a mate's tacho in a ae93 sx, i used a RPM signal that sits behind the Diagnostics box for external gauges.
    I have a haynes or gregory manual around the house for your model camry. I can check for you when i find it.
    is firing on all eight. Carport Converter AndyTTR's Avatar
    If you cant find the pin out diagram you could splice off hte 'IGN -ve' plug on the diagnostics plug.
    South australia
    yeah i had mine hooked up in my old car to the coil and it worked fine
    As an electrical engineer, and fellow toymodder... i strongly suggest against farkin with the wire that goes between ya coil and the ECU. The loading on that wire can become intermittantly too heavily loaded for the ECU to pick up a proper signal, and it can easily become an UBER hard to trace fault... even after several years of faultless operation. It only takes one lean out at high rpm and heavy load to burn a hole in ya piston.
    Forum Sponsor Grease Monkey
    to the side of the diagnostic plug under the bonnet will be a socket marked IG, its seperate to the other pins in the diag plug. Use this for the signal for the tach and you shouldn't have any problems. Just be careful with the wire that you run, make sure that the joins are well insulated etc if you short this pin to ground the car won't run
  1. AE82 rpm tacho signal
    Last Post: 15-01-2006, 09:42 AM
  2. RPM Tacho Wire
    Last Post: 10-01-2006, 09:38 PM
