first of all, delete your double post, so nobody answers that (or change the topic to "delete please")
do your bushes need replacing? my 23 year old toyota original rubber ones are still going strong, replace the LCA bushes with superpro ones recently but didn't notice a vast improvement.
AE92 i'm not so sure, but i cant imagine they would be super difficult.
bush press you shouldn't need, i replaced mine with a big vice and a hammer, balljoints too. do a search for how i did this if you need more info.
chuck up a photo of the bushes you have, we should be able to tell you if they will be difficult to install (photos of the suspension bits would be good too)
what TRD springs did you get? i'd see what else uses the same springs for the rear, or just get a full set of king lows. otherwise you could get the rate of the fronts measured, then get a new set of rears made with the rate in the same proportionallity than the TRDS
(for rough example, if kings are 3kg front 2kg rear and the TRD fronts are 6kg front, you would get the rears made to 4kg/mm mind you the king rears will msot likely be progressive rate which will upset things a bit)
buy spring compressors, they are sheap and you will grow friends wanting to use them.
i don't know about mechanics, but i never blame my tools. i know when i can get away with using cheap tools, and i know when i need to buy good ones.
the actual saying is "a poor workman blames his tools" it means that the person spends all their time blaming their poor workmanship on things, instead of striving to be better. it doesn't mean "a good workman puts up with shit tools"
good luck!
