Results 1 to 5 of 5
Thread: Changing 4age rocker cover gasket
    brapbrap Domestic Engineer samoo's Avatar
    Default Changing 4age rocker cover gasket
    Im a mechanical newb, and im going to change the rocker cover gasket on my 4age. Is there anything I need to know of, or be careful of other than
    1. undo
    2. gasket off
    3. gasket on
    4. do-up?
    no more aw11
    mx73 and brap brap time now
    Default Re: Changing 4age rocker cover gasket
    you have to give a dab of seal packing aka toyota goo in the corners where the cover goes over the bearing caps. Other than that, just make sure everything is as clean and dry as you can get it before you button it all together.
    Dan
    is there an alternative to toyota goo?
    ie something i can buy from supercheap since theyre open on sundays?
    no more aw11
    The gasket has rubber where it goes over bearing caps, ive changed about 3 of them with no goo and they havent leaked. If anything they tend to seep a little oil on the front above the headers and on the gearbox face side of engine.
    Also you might wanna but some of the cam cover nut washers. Theyre a metal/rubber combo - you could use your old ones but if your gasket was dead then these will be too once you take them off. You'll see what i mean when you take the cover off but you could always use yours for the meantime - they shouldnt be too bad if your careful taking them off.
    - LeeRoy
    yeah its just gasket sealent stuff....get the black stuff as it tends to be better,
    you do need a lil of it, tube of the stuff is only $10, as will do atleast 3-4gaskets
    blake
  1. Is a 2TG rocker cover gasket same as a 3TGTE?
    By Ta22boy in forum Tech and Conversions
    Last Post: 25-02-2007, 05:38 PM
  2. 2tg half moon rocker cover gasket
    By auzzi_17 in forum Tech and Conversions
    Last Post: 26-10-2006, 04:53 PM
  3. Quick Q - 2JZ / 1JZ Valve Cover Gasket
    By AndyTTR in forum Tech and Conversions
    Last Post: 30-09-2006, 11:10 AM
  4. Rocker Cover Gasket Sealant
    Last Post: 19-03-2006, 07:42 PM
