Results 16 to 30 of 57
Thread: benifets of 20v head over 16v head turbo'd
    Feb 2007
    Timaru
    Default Re: benifets of 20v head over 16v head turbo'd
    Quote Originally Posted by shinybluesteel
    research is all well and good, but turbo selection will be much more important than what head you end up using.
    Exactly, there's more power to be made or lost by what on the intlet and exhaust sides of the head, than what in the head itself.
    - KE70 Corolla Dx -
    - 500hp+ 7AGTE 20V turbo -
    - MRS/Hayabusa turbo **sold**
    perth
    mmmmmmmmmmmm big ports.
    thats some very nice porting work there, someone spent a bit of time on that one
    perth
    thanks sam q a few hours went into it, i was sneezing ally for days
    this was another one in an ae82
    S.A
    What valves are you using??
    perth
    just standard size , i was going to go oversize but i thought ill wait till im chasing hp so i can say "i could put bigger valves in"
    n.s.w
    Intresting debate after all of that i think i tend to lean towards the bigport 16v due it's big ports, simplicity & i think just being a more reliable head to use, i'm thinking now of extensive porting, cams & o/s valves, big plenum money better spent there than on a 20v. Don't get me wrong it sounds great having a 20v turbo with it's vvti & all i think its better suited for NA.
    S.A
    I thought you said you were aiming for 200kw. I take it we are talking at the wheels ?
    All the mods you have listed will go alot further than that.
    All you need to make 250 rwkw is a bigport head and big port cams + around 24 psi boost.
    I wouldnt bother with the OS valves and cams they arent needed to make good power.
    Spend your money on a decent turbo as the T28 you have will struggle over 200kw wt the treads
    n.s.w
    Yeah 200kw+ !!!! What about welding up the wastegate & going external?
    S.A
    That wont give you any more power out of the turbo.
    n.s.w
    Maybe a gt30 or something??? I'd just like to say your mkII is a great package saw it in zoom
    awesome mate. Family friend of mine had an original gt mkII 440, gt ho rear wing, black stripes on white the original wood grain dash with gauges, kent 1600, that thing handeld like a go kart he neglected it due to moving house to many times & ended up giving it away for free
    S.A
    Depends on how much you can afford but if you were gonna do cams plenumn O/S valves etc i guess if you dont do them this will be no prob.
    GT2871
    http://www.horsepowerinabox.com/HPIAB2/category12_1.htm
    P.S pm sent
    Feb 2007
    Timaru
    Quote Originally Posted by 30psi 4agte
    I agree with that.
    I make just over 200kw with mine and it is quite modified and maxed out on flow.
    For what the turbo itself now owes me I wish I had got something bigger, better, and cheaper.
    - KE70 Corolla Dx -
    n.s.w
    It's a GT28.
    GameOn Backyard Mechanic Poggy's Avatar
    Dont flame me everyone but, i got my 20v blacktop head flowed along with my 7afe head and considering they had the same intake systems and cam profile, the blacktop only flowed 2hp more then the 7afe. The blacktop and 7afe heads inlet ports look like brothers, very straight and sit on a very nice angle for KW's the smallports inlet ports are very flat, yeah they are big, but the design isnt as good as the blacktops, plus the blacktop boosts vvt which will allow the use of higher lift cams without suffering low down, which will help the boost come on lower in the RPM range.
    So if you want a Huge flowing Dyno king use the bigport, but if you want a very usable power curve/street driver use the blacktop.
  1. twincharging prototypes needing constructive critisism (SC14 + turbo)
    Last Post: 11-10-2014, 01:02 AM
  2. Turbos 101
  3. 2TG Turbo Upgrade - Advice/help please
    Last Post: 22-01-2007, 11:12 PM
  4. 7m-gte turbo leaking, need help...
    By shaun185 in forum Tech and Conversions
    Last Post: 05-01-2007, 08:58 PM
