Results 1 to 5 of 5
Thread: Different pintle height Q
    Default Different pintle height Q
    Hi guys, I have a "set" of 4 x 550cc injectors, which I am planning to use. Having a gander at them, before getting them cleaned and flowed, and 1 injector, has a pintle height of a millimeter, or so less than the others.
    This begs the question, will this be a problem?. Do not want to clean 'em and then have to toss them.
    cheers Chuck.
    MS51Crown Coupe,
    S.A
    Default Re: Different pintle height Q
    Is it just that the cap that sits on the end of the injector is not on all the way ???
    Most injectors have a bakelite or steel end cap that surrounds the pintle. This can be removed.
    If this isnt on as far as the other injectors and will cause the pintle to be at a different height.
    Can you post a side by side pic of the injector in question and the good one.
    perth
    a mill is a pretty big differance id make shaw everything was the same even if one was yellow and the rest blue.
    Could also be seized Chuck?
    Looks like I will have to pull the little festers apart. Valid points from both 30psi, and GT8.
    thanks for your help, cheers Chuck.
    MS51Crown Coupe,
  1. How good is a 7AG?
    By Ben Wilson in forum Tech and Conversions
    Last Post: 15-10-2006, 12:36 AM
  2. Aftermarket engine management and injectors
    Last Post: 14-05-2006, 01:05 PM
