Results 1 to 15 of 17
Thread: 20v wiring diagrams?
    T'ville, QLD
    Default 20v wiring diagrams?
    hi guys
    looking for a silvertop wiring diagram i cannot seem to find any that are 1 in english or 2 if in japanese can acutally be read (i do have the ones of turbocorolla but i cant read the damn things)
    the other alternative is if someone can confirm which wire from the ignitor/coil is attached to the main ignition relay i have what i think is th right one but id like confirmation
    thanks
    luke
    2T out 4A in....
    Junior Member Carport Converter 4agte's Avatar
    Default Re: 20v wiring diagrams?
    id be interested in this also
    Sorry, not correct.
    ive got a heap of 4a materials at home when i was planning this one.
    see what i can find.
    Black Betty >HERE!<
    (\__/)
    Black Betty >HERE!<
    (\__/)
    what's wrong with club4ag??
    ...... butt scratcher?!
    T'ville, QLD
    cant read the kanji that tell me the colours
    i miss referenced in my first post i have the ones from turbocorolla not club4ag. either way i still cant figure it out from those diagrams
    2T out 4A in....
    ah? multimeter will tell you which wire.
    or even rip the covering off the loom.
    or look at the wires and see what colour is on both items?
    Black Betty >HERE!<
    (\__/)
    T'ville, QLD
    how can a mulitmeter tell me which wire goes to the relay from the ignitor and coil? there is a wire i suspect to be the one, but am not sure (white/red IIRC) i was looking for confirmation/ a diagram to do so,
    i have completely stripped the loom of all unnesicary bits, so its basically ecu, afm, ignitor, coil, dizzy etc, what i failed to do was note which relay was what
    2T out 4A in....
    switch the multimeter into resistance mode.
    reads 1. touch the probes together you get 0.00 (some may buzz even)
    apply a prob to each end of the wire you think. 0 reading means the signal went from one end to the other.
    even pick one pin on the relay end... then touch each pin at the ignitor end.
    repeat for all relay pins and you should find.
    Black Betty >HERE!<
    (\__/)
    the diagram on turbocorolla also has the plug pics which are all labelled.
    That's the diagram I used for my AE101 20V swap.
    For the rest of the wires use the multimeter method and label each wire as you go. It's not very hard once you get into it.
    Quote Originally Posted by JP
    You could also use my "uber wiring book".... but i cant bare to part with it! Too many notes in there
    just find the black with orange trace which is common to the injectors coil and ignitor
    wire this straight to yr ign terminal right near the ignition switch
    its doesnt go to the efi relay
    i think they dont run a relay on this wire just incase you get feedback and the relay stays on
    so therefore if this wire goes to ign on ign switch it will still have good thick wire and good power and when u turn car off it stops the engine
    if you need any more info ill have to chagre you for it heheheheheheheheheeh
    red 赤
    black 黒
    blue  青
    white  白
    yellow 黄色
    green 緑
    orange オランジ
    what other colours you need?
    go here http://www.aa.tufs.ac.jp/~jwb/cgi-bin/wwwjdic.cgi?1C
    T'ville, QLD
    its not that i dont know kanji its i cant read the diagram (8 years of japanese under my belt and i did remember somthing )
    so its ok if i just plumb the inj power and coil power directly to the ign? mad as, makes it easy now
    thanks for your help guys now i just have to cut up my pretty loom
    2T out 4A in....
  1. Replies: 271
    Last Post: 13-11-2019, 01:49 PM
  2. Link to wiring diagrams
    By TC1600 in forum Tech and Conversions
    Last Post: 25-02-2007, 08:06 PM
  3. 4agze air con wiring diagrams?
    By Kebin in forum Tech and Conversions
    Last Post: 29-10-2006, 01:36 PM
  4. wiring diagrams!
    By rollsy in forum Tech and Conversions
    Last Post: 08-10-2006, 04:10 PM
  5. 100kW 4AGE wiring diagrams
    Last Post: 15-04-2006, 06:03 PM
