does any 1 know how to hook up a 4 wire fcd to a 1ggte?
hey i just aquired a used greddy fcd for my 1ggte and i have no instructions on how to install it can any 1 tell me where do i splice in the 3 wires?
ok well firstly do u know what wires they are supposed to connected or spliced to? (eg -throttle pos, airflow, rpm)????
because if ya know that then its a piece of cake
'88 Soarer GT-L
'90 Supra Aerotop
no thats what i need to know heh, thier is a red and black wire which is supose its live and ground, then thier is white and green, i know 1 of them conects to the vc line in the afm, but i dont know if it splices into it or if i have to cut it completely then use either the green or white wire to feed the ecu, another theory is that 1 of the wires splices into the afm wire then the other 1 goes to rpm, i would really like some help heh
Depends on what version FCD you have but generally ...Originally Posted by Regan
- Connect the red wire to 12V power,
- black wire to good Earth,
- cut or splice the Pressure Sensor wire or AFM signal wire, connect the yellow FCD wire to the wire going to the factory ECU,
- connect the white FCD wire to the factory ECU wire going away from the ECU.
For a complete install instruction, download this file. Read carefully before starting. HKS and GReddy are interchangeable in most instances.
http://www.xspeed.com.au/manuals/fcd_install.pdf
Hope this sorts you out OK.
Peter
