Results 16 to 30 of 37
Thread: 1uz-fe + V160
    Default Re: 1uz-fe + V160
    Quote Originally Posted by gianttomato
    I don't know anyone who has one handy.
    That adaptor ring would go well with this....
    Eeek... freaky carb'ed 1UZ
    Nice ****** Grease Monkey rvrolla's Avatar
    Dumb question, dont worry
    ToyotaCarClub.net Domestic Engineer Starfire's Avatar
    They look like gas carbs to me... Ugly but makes the thing somewhat cheaper to run.
    What it really needs is 8 throttles and a set of trumpets...
    I would have thought they were SU carbs, although gas carbs make more sense seeing as SUs wouldnt flow enough for that.
    They be SU carbs, same interesting vac design for actuating the float bowl at the top.
    bahahahaha that pic is gold
    + rep
    KE38 - 2TG
    MS65 - 1UZ
    Dave.... you give me scary thoughts about raping a certain car i own with this talk of 3VZ engines .....
    Karl, same engine mounts, adaptor ring and flywheel.
    The 1UZ pictured above has 2 2" SU carbs and has has 2 Prelude distributors grafted on to the cam gears. It is currently for sale for $900 on Ebay.
    But what of the MZ series engines? Why hasnt anyone gone down that path yet??
    Like most other motors, its a PITFA to convert from FWD to RWD
    .... and?
    stick one in an AE82!
    But then you're still left with a shopping trolley, only now it cant turn.
    sa
    Pfft! all you need to do is rig the powersteering up to the front brakes and it'll turn fine!
    Brake one wheel and use the torque to turn
    Though if you mounted it in the rear of a seca in an errr.... south-north orientation and chucked a diff at the front it could work
    Reverse donuts sure would be fun.
    but it's all alluminium.... sif it'd weigh much more than a 4agze?
    The 4A is pretty small. It's probably taller and just generally bigger too.
    I vaguely recall someone saying an MZ V6 could be mated to a W58 via an S-series bellhousing - but the starter motor would probably require some kind of engineering (unless it's in the valley?).
    Width (with headers) would be interesting to find out about these motors - have notices a few V6 wagons at the Wacol ABC wreckers and have (foolishly) wondered how they might go in a RWD car.
