Would this be the meanie known as Blow-by?Originally Posted by urantia
Maybe check if the dipstick keeps getting blown out, by a little bit, of its holder?
Eldar.O.
Firstly i would run the thing and try pulling off the ISCV and TPS one at a time. Both should affect idle. If nothing happens test it more thouroughly. I am more sus on ISCV, particularily if (as per Takai) it uses wax pellet thing - i am not familliar with this but have heard about it being inconsistent.
If you restict the inlet, it should run a bit rich. This should either bring the idle up a bit or make it die altogether coz your plugs are the problem (gap or sealing cylinder properly)
Eldar.O.
No experience with this problem or motor, and it may have mentioned in some other form but has automatic choke beem considered, assuming they're on this motor.
Sorry for my ignorance but just tryin to help and maybe learn a thing or two.
Cheers, Pomey!
That woudl be the ISCV.Originally Posted by pomey
Blowby is where compression gasses find their way past the rings and pressurise the crank case. Normally this is mainly manifested by having lots of oil coming out of the PCV. But occasionally it can pop the dipstick. Only very occasionnally.Originally Posted by EldarO
eldar O, You'll find just about all 3s engines have abit of blowby. And with the gen1 don't actually have a pcv valve, but a fixed orifice for reburning oil vapours/oil, blowby.
Even noticed very low Km beams motors red top and black top have quite abit of pulsating air coming from the oil cap.
Pomey, it's been a fair old while since cars have had a choke. Thankfully...
Edited post.
yes, believe me i have checked quite alot of things.
This sounds very close to the problem i have with mine. Sometimes the power just isn't the same, and the idle acts up. It drops to 500 or so then bounce up to 700 and back down again etc etc till it equalises out.
Kind Regards,
Kurt.
1998 ER34 ニッサン スカイラインGT- T
