when mounted on the firewall, the downwards-facing outlet goes to the heater core, the outlet pointing horizontal goes to the outlet on the water pump
The other heater connection gets plumbed in from the block or somewhere near the back of the motor.
is a closed system, heater core is under the same pressure as the engine cooling system - the tap simply stops flow, it doesn't reduce the pressure that the heater core gets.
