Results 1 to 15 of 19
Thread: GZE rebuild time!
    Default GZE rebuild time!
    I think that my poor and hard-done by 4A is getting a bit long in the tooth, so it might be time for a freshen up. What does everyone recommend as good budget performance rebuild gear? I was thinking:
    8.9:1 Toyota pistons
    ACL RACE series bearings
    ARP bolts (maybe)
    ACL or toyota genuine gasket and seals kit
    Balance crank/flywheel/rods
    Block acid-dipped
    Re-grind crank/bore if needed
    Reccomendations? It's destined to be a street engine, maybe turbo, maybe SC, I'm still deciding, but around 15psi. Occasional use at hill-climbs/super springs etc...
    Cheers, RM.
    Junior Member Backyard Mechanic cri_ag's Avatar
    Default Re: GZE rebuild time!
    yep thats basicaly the specs of my motor, maybe slightly higher comp pistons but? cant remeber have to check still standard toyota gze's but. got tuned on friday 190kw, 500nm, 17psi.
    what else are you running on your motor? Sounds pretty beasty...I think the early GZE pistons are 8:1, the later smallport pistons are 8.9:1. I was leaning towards them to make the engine more efficient, especially if I go turbo, try and get rid of as much lag as possible.
    RM.
    Edit: and how much did all the bits cost you?
    Feb 2007
    Timaru
    FYI,
    I changed the pistons in my 20V turbo from the early model 8.1 to late model 8.9 ones,
    and that made boost arrive 1500rpm earlier.
    The higher your compression ratio, the less boost you have to run to make power,
    The better your off boost response is,
    and the sooner it will make good boost, ( less lag )
    yea ive got the later gze pistons so it must be 8.9:1, im running a gt2871r on a short runner steampipe manifold i made myself. haltech e6k running haltech twin output coils, wasted spark setup. 450x300x76 just jap cooler, 2.5inch cooler piping, 2.5inch exaust. tuner said there was more power in at that boost level, but he decided to leave it just slightly on the rich side.
    and it spins the wheels when it comes on boost in 1st 2nd and 3rd gear!
    S.A
    The specs you have listed are spot on. No need to do much more to make good power. 200+ rwkw with the right external bits.
    Might suggest a port job and some cams in you can budget for that.
    S.A
    Quote Originally Posted by cri_ag
    Imagine what another 100+rwkw makes life like
    haha the stock diff doesent like it at this power level!
    I've got WADE 267s, so the cams are taken care of The other bright idea that came to mind today was a 7A-GZE, since I'm building a motor anyways, I might as well get some more CC. Plus, the SC14 doesn't really like high-RPM, so if I loose a bit of top-end possiblities, it's not such a biggie...I'm still teaching myself all the 7A foibles, but I've heard they have a low CR with a GE head (I'd use a bigport) Does anyone know what CR the 8.9 GZE pistons would give in a 7A, and also what a decent set of rods would be worth?
    RM.
    Feb 2007
    Timaru
    Quote Originally Posted by mullett
    I Does anyone know what CR the 8.9 GZE pistons would give in a 7A, and also what a decent set of rods would be worth?
    RM.
    With a 20V head and 8.9 pistons I measured it out to 9.03:1 compression ratio.
    Still searching rods but $180 US plus freight each is around where they are.
    - KE70 Corolla Dx -
    - 500hp+ 7AGTE 20V turbo -
    - MRS/Hayabusa turbo **sold**
    So 8:1 early GZE pistons might be the go for a boosted one then...hang on...the 20V head has smaller squish chamber than the bigport one yeah?
    RM.
    Feb 2007
    Timaru
    I haven't done enough with the 16V to say either way.
    - KE70 Corolla Dx -
    Argo list 7A rods, Pauter also do them
    good stuff! I'll keep reading...does anyone know the rough difference in combustion chamber volume between the two heads?
    RM.
  1. 4agze rebuild options and interchangable parts
    Last Post: 13-08-2006, 04:27 AM
  2. To rebuild, or not to rebuild?
    By Shifty in forum Tech and Conversions
    Last Post: 04-04-2006, 11:37 AM
  3. 22RE rebuild
    Last Post: 20-03-2006, 08:56 AM
