Results 1 to 6 of 6
Thread: 5 stud conversion to AE92
    Default 5 stud conversion to AE92
    Has any one done a 5 stud conversion to an AE92. I was thinking of looking into the ST celica's for donor parts.
    Cheers.
    Default Re: 5 stud conversion to AE92
    just get the 4 to 5 stud bolt on spacers...
    i dont know why though.....most FWD offset rims are 4 stud....
    blake
    Maybe 20 series Camry? Are there many wheel options for 5 x 100? Later model Camry has 5 x 114.3.
    Junior Member Grease Monkey .:2DR-FTU:.'s Avatar
    New South Wales
    5x100 is mainly shitty wheels with larger sizes. Why the hell do you wanna do this, like a larger brake conversion? If thats the case, get some new holes drilled to use existing hubs or something.
    Quote Originally Posted by Cow Cow
    Here in Hong Kong, I have a Echo 1.3
    I put in a TRD exhaust manifold, TRD quick shift gear stick, K & N Air Filter, Ground Cable, NGK E spark plugs, 2 pcs of Voltage Stabilisers and twin HID systems.
    It goes like a rocket.
    Montrose
    'cos 5 studs is just cool, OK?
    Gone from 005 to XR5! Automotive Encyclopaedia Matty P's Avatar
    I've been shopping for 5x100 wheels and it seems that there are more choices in 4x100!
    If you are going to go 5 stud, then 5 x 114.3 would probably be a better option - as far as wheel choice goes at least.
    By The Witzl in forum FAQ
  2. Early corona 5 stud conversion and big brake's
    By SRacin in forum Tech and Conversions
    Last Post: 22-09-2010, 10:32 PM
  3. 5 Stud Conversion on RT142?
    By Adash=P in forum Tech and Conversions
    Last Post: 29-12-2006, 01:37 AM
  4. Replies: 2
    Last Post: 04-08-2006, 07:25 PM
  5. Replies: 97
    Last Post: 31-01-2006, 12:43 AM
