Results 1 to 10 of 10
Thread: 18rg running temp?
    Default 18rg running temp?
    Just wondering what the water temp should be for the 18rg. My hilux had a 18rc now its got the 18rg and needle sits higher on the rg to the rc.
    Default Re: 18rg running temp?
    Mine sits at 78-80 degrees C. When it's a stinking hot day, traffic and the air-con going it can get up to 82 deg C.
    seeyuzz
    river
    mine floats from 77 up to 90*C.
    I have a thermofan on mine which is set to switch on at 90*C and off at 86*C, as opposed to the stock clutch fan setup which tends to keep temps down constantly in traffic.
    On highway, mine sits at 78-82 constantly.
    ...... butt scratcher?!
    south australia
    if anything mine takes what i would consider an excessive time to warm up, (over 10 minutes usually), it hovers around the 80 degree mark once there however give or take 2 degrees, just like above
    when it did run high, i redid my head gasket and it fixed it.
    are you just using straight distilled/demineralised water in the coolant system until you are sure or does it have the glycol(coolant) stuff in there also?
    Quote Originally Posted by barned01
    i only just finished installing the motor in the hilux so for now im just using straight tap water. the heads been completly rebuild and rings bearing ect, replaced. I guess ill have to get an aftermarket water temp gauge.
    Classic Not Plastic Domestic Engineer ace's Avatar
    Quote Originally Posted by ganador
    Not very smart....
    My TA22
    Quote Originally Posted by gianttomato about new cars
    Yeah sure, it goes alright and it's got air conditioning, cup holders and automatic tampon removers, but where's the charm?
    Quote Originally Posted by ace
    Not very smart....
    i was thinking that too
    put some coolant in it ffs
    not that cheap shit thats 65g/L. put something with a nice high concentration so your head doesnt corrode.
    its in there for when i started it up. im still getting new hoses and stuff. I'm not driving it anyway its still getting bit and pieces done to it.
    south australia
    yeah matey, if you just want to put water in it to test, grab some demineralised water from woolworths/safeway at the very least.
    It only costs 2 or 3 dollars for 4 litres (you need 2), and it is better than tap water, especially after you have spent all that money on reconditioning a head. you also don't care as much when you find something wrong and have to drain it out (yeah been down that path a few times ).
    with demineralised water only, i was still getting around the 82 degree mark when i built mine.
    Yeah might do that. and ill should have the money for the head by thursday. sorry its been taking so long, im a poor bitch.
  1. Misfire / Running on 2/4cyl 18RG help.
    By TA-022 in forum Tech and Conversions
    Last Post: 20-01-2007, 12:41 PM
  2. 7MGE running temp
    By JesseCrown in forum Tech and Conversions
    Last Post: 17-03-2006, 06:59 PM
