what car is it for?
ive got secondaries from a stock ae111 if thas what ur chasing
craig
Hi, can somebody tell me where I can find an engine pipe for a 20v. I need the part that bolts onto the exhaust manifold. I have the primaries (section 1-2) but I need the Secondaries (2-1 section)? Can anyone help?
what car is it for?
craig
Te71 Corolla Levin, Blacktop 20v
Te71 Corolla Levin ex Rally Car 2tg.
Te71 Corolla Hardtop 2dr Sedan, 2tg/3t waiting
Ke70 Corolla 4dr Sedan
Ae86 Corolla sprinter 4ac
Corolla Feind
Yes, that's what I want. My car is an ae82. I need the secondaries for a 20v that came from an ae101. I assume that the secondaries are the same. Thanks. I'm from Melbourne though, how much would you want and how much would postage be on something so big and heavy?
Dave
Ahh i was looking at this today actually.
It looks like to me that you could redrill the 20v extractors and fit it to the different style flange on the ae82 secondaries.
Or yes you could just get the 20v secondaries.![]()
I didn't think the pipes from the 20v primaries line up with the ae82 secondaries. Does anyone from Victoria have the 20v secondaries or know where I might find them?
Thanks for the fast replys.
Dave
i've been after a set of these for a while also
anyone in nsw got any they wish to part with?
Ok, Im going to redrill mine and see how they turn out. I put the ae82 headers and the 20v headers next to each other and they look possible.
I'll post em up to show you guys when i do it.
you prob need an o2 sensor too if you need those pipes as thats where it sits
if your running std ecu
or any other semi decent closed loop ecuOriginally Posted by sideshow
as cuzzo said either redrill or take to an exhaust shop and get them to cut and then make a flange for it, simple
As i said, I don't think the pipes will line up so redrilling will not work unless a custom flange is used. Lets wait to see how Cuzzo's redrilling turns out......
Ok i had a closer look at these today and i am mistaken. The actual pipes on the 20v manifold and the ae82 manifold are out by about 5-10mm.
Hmm if only i had a picture...
Where the actual exhaust gases flows through doesnt quite line up with the ae82 ones. The ae82 ones split by about 5mm but the 20v ones are split by about 10mm.
Sorry for getting everyones hopes up.
Yep cut and weld or find 20v secondaries
Originally Posted by cuzzo
Just as I thought, why oh why couldn't they be the same.
Dave
