Sounds like you might have a vacuum leak somewhere. Check around the carby mounting plate gasket and intake manifold for leaks. You're relying on the motor's vacuum to pull the fuel in through the carby. Spray some carby cleaner around the carby to see if the idle changes, if it does then you know you're close to where the leak is. If you want to do it old school, get a piece of flexible hose and hold one end to your ear and the other around the carby, listen for a hissing noise, when you do hear it you will be around where the leak could be.
The secondary idle jet is for a smooth progression from the primary butterfly being opened all the way to the opening of the secondary butterfly. The leak could be coming from this hole if there's nothing in it.
To help you understand a bit more with diagrams have read here:
http://www.webercarburatori.com/?p=handbook
It got me out of trouble a few times.
good luck.
