1. yes.. non-heated sensors should be maybe 30-40cm from head, but in turbo apps, the heat before turbo is too high.
heated sensors can be anywhere. you can run them a few feet back at least. they are best as you no longer have a signal that varies with temperature of exhaust (at least from low temps)
if the sensors are too close to head, or temp is too high, then can fail...i think usual temp is 3-600C perhaps?
2. if you get signal from one cylinder, you only get info from that cylinder. putting at junction will get info from all cylinders.
if things are normal, it makes no difference (as long as you have heated sensor at junction, or it stays up to temp), but if you start dropping one cylinder, you can see the change if you are datalogging fast enough when the sensor is at the junction.
that help?
footnote.. heated sensors ftw!
