Results 1 to 5 of 5
Thread: brake vacuum
    Eltham vic
    Default brake vacuum
    hi
    i was replacing the vacuum hose
    and i noticed what appears to be a restrictor is this a neccesary part or can i just connect the power booster straight to the inlet manifold
    ian
    Welcome to the Darkside! Automotive Encyclopaedia -==L=a=N=c=E==-'s Avatar
    Rosewood
    Default Re: brake vacuum
    it's a one way valve. Be a good idea to have it.
    Eltham vic
    hi lance
    i sucked the valve and it seems to restrict the flow a little more one way and not the other
    what i mean should it close completly one way
    ian
    Ian, the valve will either have an arrow on it indicating direction it flows or manifold etc will be stamped on it indicating which end should be connnedcted to the manifold and the booster.
    If functioning properly it will only flow air in ONE direction, if it flows freely in one and partially in the other then get a new one as it is stuffed, they are cheap and are a crucial part of your braking system.
    One way check valve! Available from any parts store or brake shop.
    My KE25 thread
    Eltham vic
    thanks yld and lance
    ian
    By The Witzl in forum FAQ
  2. 20V Brake Booster Vacuum Problems
    By ShiRi in forum Tech and Conversions
    Last Post: 15-12-2005, 07:06 PM
  3. Rear Disc Conversion for FWD Cars
    By wagonist in forum FAQ
  4. Brake upgrades for FWD/AWD 5x100
    Last Post: 06-09-2005, 11:38 PM
