Results 1 to 3 of 3
Thread: FCD in MZ21 problems
    SO00RA Domestic Engineer 4agerolla's Avatar
    Default FCD in MZ21 problems
    I recently found that my car has a fuel cut defencer, but at the time it wasnt connected properly. I found a wiring diagram for it > 7m and found that wire x from the ecu had already been cut and intercepted by the FCD in the past, but for some reason the past owner must have disconnected it.
    I connected it back to how the diagram said and started her up..... idled pretty much perfect (as well as the old 7m does). As soon as i applied any throttle though the revs drop dramatically almost to the point of stalling unless i release the throttle.
    I adjusted the FCD to max in both directions (standard cut vs less cut) and the same problem... Whats the deal!!!???
    Edit: As soon as the FCD is unwired from the car it runs as per normal.
    Any help greatly appreciated
    chris
    - Silver 2012 Lexus ISF - 2UR-GSE 5 litre V8 goodness
    - Black JZZ30 Soarer - 1JZ-GTE VVTi + factory R154 manual
    - Blue KE17 Sprinter- 3k + K40 manual
    - White MS55 Crown - 2M + 4 speed column shift manual
    - Blue MS51 Crown Hard Top - Angry 4M-B + W50 manual
    Junior Member Backyard Mechanic cptsideways's Avatar
    Dorset
    Default Re: FCD in MZ21 problems
    It'll need an earth, a live & the two other wires T into the one of the ECU wires (AFM output I think) so the afm wire is cut, join that to one end, the other wire joins to the ecu side of the cut wire.
    Sounds like one end of the wire is not connected, as soon as the revs rise theres no afm signal
    Sliding his D1 Soarer around the UK
    Quote Originally Posted by cptsideways
    Thats exactly whats been done, yet still no good! im baffled... unless the pos and neg wires arent connected properly, i didnt think to check that! Remember kids assumption is the basis of all f*ck ups!
    chris
  1. Problems solving 4agze
    Last Post: 28-06-2006, 07:21 PM
  2. Cooling Systems - Overheating Problems.
    Last Post: 24-06-2006, 09:40 PM
  3. 1G-GZE - My Problems !
    By ra23celica in forum Tech and Conversions
    Last Post: 20-03-2006, 01:21 AM
  4. 4AC Problems....
    By Rallystanza in forum Tech and Conversions
    Last Post: 04-02-2006, 10:36 AM
