Results 1 to 6 of 6
Thread: Consequences of disconnecting ISCV on 4agze
    Jan 2007
    Default Consequences of disconnecting ISCV on 4agze
    I was wondering if anyone knows what the ECU will do an a 4agze if the ISCV is disconnected/removed and plugged up.
    Necros
    Nay sayer Domestic Engineer Mr Ed's Avatar
    May 2006
    Default Re: Consequences of disconnecting ISCV on 4agze
    It goes purple and dances like a chicken
    I used to eat alot of natural foods. That was until I learned that most people died of natural causes.
    OOPS 10 characters
    MS51Crown Coupe,
    Jan 2007
    What have you guys been smoking?
    BTW, I've D'C'd the ISCV and the car idles fine at 1500rpm (air bleed adjustment to be done yet).
    try bringing the idle down to a sensible 900 rpms or so and tell me if it idles with a fluctuation less then 100 rpms..
    if that is possible please tell me how it's possible.. otherwise i'd think that disconnecting the iscv makes it sound like u've got very big cams and will not idle properly.. ?
    Victoria, Mt Macedon
    As you may already have worked out, running no ISCV will not do anything bad (maybe stock ECU will throw a code though). You'll just need to adjust the manual idle bypass up a bit so it doesn't stall cold. Or get good at heel and toeing so you can keep it running as you pull up to lights.
    Hen
  1. 7MGTE ISCV Dilemma
    Last Post: 05-10-2006, 07:19 PM
  2. 4agze rebuild options and interchangable parts
    Last Post: 13-08-2006, 04:27 AM
  3. 4agze questions
    Last Post: 14-06-2006, 08:50 PM
  4. AE101 4AGZE wiring diagram Needed
    Last Post: 28-04-2006, 12:29 PM
  5. 4agze conversion
    Last Post: 02-03-2006, 08:52 PM
