aren't normal fuel pressure regulators 1:1 ratio.. ie, not rising rate??
this is usually done so that thepressure differential across the injectors remains the same..
rising rate is like 1.5psi per pound boost, or whatever..
i'm not sure i follow you with the fuel/revs argument?
usually, the rail pressur eis 40psi over manifold, and a rising rate will increas say (for example) 1.5psi per boost, so 20psi boost = 40+30psi = 70psi..
the main danger with running a RRFPR is that most fuel pumps start to flow poorly over 60psi or so...
there are published flow charts for at least the walbros and the bosch pumps...
so as you up the boost, you start losing fuel flow, cos you are asking it to supply at a higher pressure (and can have dangerous sudden leaning up top)
fuel requirement increases with air, ie, both boost and rpm....
with a RRFPR, usually what would happen (without other mods) is that with increasing boost, you run richer and richer...until the pump can't produce flow at that pressure and it all goes bang![]()
(cos the rate of increase is not rising???)
