You should be -ve repped for putting a Holden V6 into a Toyota![]()
Whilst installing the commodore V6 into my YN57 hilux, i discovered the fuel outlets out of the fuel tank are a fair bit too small. After going to the trouble of braising up a new fuel line, and melting the rubber gasket, i went to the wreckers to get another, i discovered that the LN40 - (i guess all diesels would be similar) - actually has a bigger fuel outlet - and is the perfect fit into the YN57 tank - problem solved!
Thought this might stop the rest of you with petrol models looking for the bigger lines.
Blake
Daily: Toyota '05 Rav4 Sport
Why where you changing the outlets on the tank?
I hope your not running it without a surge tank
im using the orig outlets with a lift pump then surge tank with which goes into a bosch 984 and then lines that are twice the size of the originals
of courseOriginally Posted by bansheebuzz
I got a lift pump filling a surge tank then double the size lines the rest of the way. Iwas thinking of a bigger tank though. I seam to have a problem driving conservitively....
Petrol is for washing parts, alcohol's for drinking but NITRO IS FOR RACING!
My pictures, Returning some time in the distant future.
RN85 Hilux + 1JZ-GTE = 298.0HP @ 14PSI -- 60' 1.956 ET 13.775 MPH 99.49
Project Korruption - Stage 1: The Resto. KE35 Corolla Hardtop daily driver
i fitted a nissan rb25det efi fuel pump directly inside the tank hose clamped to the origianl 6mm fuel pipes then run 8mm after the tsank to engine
took 20 mins to make and never have any probs
