Haha, did you break witzl's gearbox?
After more than a year of procrastination Project 6-speed is finally underway! For those who don't know, I'm putting a Getrag V160 (JZA80 Supra TT 6-speed) into my 1984 MA61 Supra.
Progress so far isn't much but it's a start: removed the broken W58 5-speed, thoroughly degreased it (apparently the rear main seal is FUBAR) and took a few photos next to the V160. I haven't taken any proper measurements but as you can see below the 6-speed is freaking HUGE!
http://www.norbie.net/Project2JZ/Six...mparison01.jpg
http://www.norbie.net/Project2JZ/Six...mparison02.jpg
http://www.norbie.net/Project2JZ/Six...mparison03.jpg
http://www.norbie.net/Project2JZ/Six...mparison04.jpg
http://www.norbie.net/Project2JZ/Six...mparison05.jpg
http://www.norbie.net/Project2JZ/Six...mparison06.jpg
Still to come: detailed measurements and an initial test-fit. The latter will have to wait until I can get some volunteers to lend a hand - the 6-speed is as heavy as it looks! I can just barely manage a solo W58 install, but no chance with the V160.
Norbie!
www.norbie.net
600 Club Member: Toymods Large Member
MegaP00 - 7MGTE Skunkworks division
RIP - Nathan Dean (TA-022)
I'm afraid I did. It actually lasted a lot longer than I was expecting though!
Norbie!
www.norbie.net
Far out thats huge!.
How do you plan to tackle the different shifter postion?.. looks like there is a fair difference.
How much and where do you find a a V160? Also thing that would make the conversion alot more difficult would be final ratios. As I'm sure you know the overdrive gear, 6th is only like .793 but makes up with the 3.2ish diff. What diff ratios are you going to use?
Also usefull link for putting a 2jzgte with V160 into a MKiii. May have already seen it but it does have some info on how modified the V160 shifter to suit.
http://www.turbosupras.com/pages/en/...conversion.htm
good luck, looking forward to this.
Haven't given that much thought yet, I'm more worried about getting the box in the tunnel to begin with.Originally Posted by Hybrid
The box was about $3k (bare) which I sourced from ImportBitz. I'll need to buy about $500 worth of stuff new from Toyota to get the crazy clutch mechanism working, it's way more complicated than the W58.Originally Posted by Big rob
The overdrive ratio is nearly the same as the W58 so I can't see that being a problem. I currently have a 3.58:1 final drive ratio and I have no intentions of changing it. The 3.2:1 ratio in the JZA80 gives it a theoretical top speed of more than 300km/h which is something I doubt I'll ever need! I've seen 270 and that's scary enough.![]()
Norbie!
www.norbie.net
V160FTMFW
I like.
I buy.
The only reason I see that there would be a need for a diffreence in comparison to a W58 is cruzing RPM. Larger capacity = more torque and therefore you can rev lower down the freeway. But I guess you have been driving with it through the W58 with similar ratios so it wont be much different.
I want to put a 2jzgte in my GZ20 and at the moment its going to be a R154. It comes with its pros and cons, mainly that stock MA70 ratios will work with it I'm just scared it may get broken. I would like the V160 but i dont know if the cost would justify it its in similar costs to an aristo half cut lol!
Holy crap, that's huge.
I hope you dont mind getting someone in the back seat to shift gears for you, haha.
Good luck, I think your gearbox breaking days will be over!
Well I hope so for your sake, those things arent cheap, haha.
*Raises hand to volunteer.Originally Posted by Norbie
Looks like the shifter would be reasonably easy to shift a fair way forward from where it currently is by cutting and shutting the three legged thingy (technical term) it is on.
When you need a hand give a yell, I do a 2 week roster away, if I am home will come around, not very smart but I can lift heavy things.
regards
jon
I dragged one of these fucking things up a steeply inclined driveway with my 'mate' (yes you Glenn ra45GTCelica!!) telling me what a whimp I was for not just picking it up and striding up the driveway with it. I managed to finally get it into his garage - he then attempted to pick it up only to rudely shocked by its weight.
We then grabbed some bathroom scales to find it weighed about 57kg.
He apologised.![]()
Norbie and i managed to pick it up when he was moving.
It was far from light.
Holy shit! I knew the V160 was big, but sitting next to the W58 it looks farken nuts!!!
Watcha doing with the 'ol W58? Ive got a mate whos after the bellhousing.
(PICS OF NEW WORKSHOP OR BAN!)![]()
I used to eat alot of natural foods. That was until I learned that most people died of natural causes.
i'll gladly rock up, drink your beer, offer unsolicited opinions on things i have little experience with and maybe get dirty once or twice.... until I can get some volunteers to lend a hand - the 6-speed is as heavy as it looks! .
Last edited by thechuckster; 06-11-2006 at 09:32 PM. Reason: doh- bad editing, was going to quote sir2j but changed my mind ;)
