- intake manifold
- fuel rail, with fuel pressure regulator and dampener
- injectors
- throttle body with TPS
- AFM + ECU
- electronic ignition
- loom
- EFI fuel system
I think thats about it?
OK..Im running a 2tgeu on carbs in my '71 TA22...
Ive found an EFI system to buy for it but the seller wants to know which bits he needs to send me exactly..
Little help needed here
Can someone help me compile a list of EVERYTHING I will need to convert?
Thanks in advance everyone...any help appreciated
~Jilly.
- intake manifold
- injectors
- AFM + ECU
- loom
- EFI fuel system
...... butt scratcher?!
Hey Jill,
Pretty sure that Karl has knocked this one on the head...
Karl when you say "EFI fuel system" I assume you mean surge tank, efi pumps etc... did you need to upgrade the fuel line size in yours?
This link may have some info for ya http://www.toymods.net/forums/showthread.php?t=3525
Its a fair bit of work converting it over, especially the wiring. Good luck!
Toyota Car Club (Qld)
Water temp sensor, cold start switch. Not sure where these are located on a 2TGEU but you'll need them - might be fitted to thermostat housing?Originally Posted by The Witzl
Water temp sensor (green plug), you are correct.Originally Posted by gianttomato
Cold start switch (brown plug) - not needed, just plug the hole. I have never hooked up the cold start injector on any conversion i've done - they are really only needed for stupidly cold conditions, the factory cranking enrichments are PLENTY.
Or.... get your carbs properly tuned by someone that really knows what they're doing. The old 2T-G EFI system will not give you any more power or performance compared to the carbs.
seeyuzz
river
Originally Posted by river
Not this again....
.... dont listen to him, he's gone senile. EFI will give you more useable power for everyday driving, with a much more torque down the lower end of the rev range.
Sure carbies have the max power advantage, but the EFI shits on them eveywhere else.
yeah dont listen to him
carbies + turbo = bad idea
you do know that eventually you'll put a turbo on right?
Well of course, if you're going to turbo it then FI is the way to go. But there was no mention of turbo in the initial post.
Also, to clarify... I'm talking about the original FI that came with these engines wasn't any better than carbs. The reason manufacturers originally went with FI was to meet emission standards, not for performance.
The latest EFI systems and ECUs offer fantastic performance.
seeyuzz
river
Originally Posted by SillyCarS
cair to elabirate on that? ive had know troubles![]()
* 73 KE26 - x4 Brown Wagz
* 73 KE20 NOW 3T-TE
* 84 KE70 Panno
* MX83 LS1 Track Car
