FYI Bril is now making over 500rwhp with that turboOriginally Posted by -==L=a=N=c=E==-
I think that sums it up. Ripped straight off SupraForums AU.
[Project] 'Bugger' - 1999 Toyota Hilux Turbo Ute - PB: [email protected] 1.857 60FT Video
[Project] 'Red Baron' - 1990 Toyota Celica GT-Four - PB: [email protected] 1.869 60Ft Video
Technical Articles Database 3S-GTE/ST185/Celica - BGB,EPC,Tech || 2RZ/3RZ/5VZ/Hilux - FSM
If in doubt power out
this i am well aware of, but a graph always makes better sense then a figure.
375rwkw on 26psi??
hmmm
so a figure of 420rwkw on the same boost is not possible? even with cams?
Jays 2JZ cressy is making 459rwkw on 1.5 bar with a T78 and cams...
Project Soarer II - Sold
Evo 5 - The silver fruitbox
want more then 380rwkw, time to goto a GT40 or GT42 series turbo... especially with the auto sucking a fair wack of power.
then a GT42 or T78 is going to be the go then...
EDIT: driveability ftw it would seem...the GT35R is gonna be the go
He's making a new dual-entry plenum. Apparently eleventy billion hp is not enough.Originally Posted by 2JZR31
Norbie!
www.norbie.net
Not even the 1.06 will do over 400rwkw (on an average dyno) 380-400 will be pushing it for most setups.
Stock 2JZ turbos will make 1 bar by 3000rpm in parallel, the GT35 1.06 (with more responsive 0.5 comp cover) will make 1 bar by 3500rpm so there is about a 500rpm extra wait. Take 200rpm off for the 0.82.
Cool. Cant wait to see how it turns out.Originally Posted by Norbie
Dont know if ya seen this site, but it helped me choose my turbo.
http://www.apc-racing.com/showentry.asp?enid=4
1994 GZX90 Mark II 1GZ-FE V12
Great link. GT3540 FTW by the looks of that!
Norbie!
www.norbie.net
I think that one came up in my T04Z vs GT35 thread on PF. Its a not a fair go on the T04Z since the car is largely overdeveloped.
Yeah, I'd have to agree with that. The garrett ball-bearing T04Z should be somewhere between a GT35R and GT40R (based on it's wheel sizes and trims, and the fact that they're all dual ball-bearing turbos... and the fact that I've read all their compressor mapsOriginally Posted by 2JZR31
You've got to keep in mind with a graph like that that they aren't all running identical setups, tuning or boost pressures, so at best it gives you a rough idea of where the turbo will start to spool on a 2jz.
dual entry plenum, about as good of idea as a square wheel
8.3 et PB 169 MPH PB
Yeah that guy has no idea what he's doing.Originally Posted by 1JZ.747
Norbie!
www.norbie.net
