Originally Posted by infotechplus
this is the best i could do at 9.00 o clock at night
if you need some more info i can do it in the daytime and get pics if you want
In hindsight I of course realise that I should have labelled all these plugs when I disconnected them from the old 22R. I'm hoping someone with a Lux and a 22R carby petrol engine (RN85) can identify these plugs for me.
I've searched my Gregory's manual without success, and old photos aren't clear enough to pinpoint connections. They are all the parts of the loom from the driver's side, including Air Con.
These are all the wires together, protruding from the Fuse Box:
These are the individual plugs:
Peter
So it looks like I don't need most of these on my 1GGZE conversion. Correct?
Peter
i would say so all the vsv's control the emission crap for the carby
that 9 pin plug looks quite important so i would probably keep that and check for a/c compressor power in the 3 pin plug
if you need pics let me know
Yes please! It's the AC that I'm particularly after.Originally Posted by ecotechilux
Aircon power is the single pin plug in your 2nd picture.
I'll try o work out the rest in the morning.
So on the plug coming up from the AC there are two wires. I imagine the other wire is earthed then if the single plug you identified is the power. Correct?Originally Posted by Lukey-KE20
Peter
I'm assuming you're using the 1G AC compressor.
On the 22R AC compressor there is only a single pin for power.
I'll confirm tomorrow with a pic.
Luke
That would be great. Thanks.Originally Posted by Lukey-KE20
Peter
on mine it is in the third picture it is the black/white wire on the 3 pin plug
i am 100 percent positve about this will confirm with pic soon
Here is a pic of my compressor. You should be able to just see a single pin on the top and an earth lead going off onto the actual compressor.
I can't show you the plug because I cut it off when I installed AC a couple of months ago. I had to run a new lead and didn't have the other end of that plug.
Luke
sorry my usb cable for my phone is farked but i can guarantee 100 percent it is the black/white wire in the 3 pin plug
if you want the pic pm me your number and i can message it to you
The Air Con switch on the dash has five (5) wires:
Black w/White stripe
Green
White w/Black stripe x2
Black w/Orange stripe
One of the W/B wires is earth, the B/O wire provides power to the A/C amplifier (which is a Blue w/White stripe wire). From the A/C amplifier there is a Black w/White stripe wire running to the A/C compressor (which is also earthed).
Here is the RN85 wiring. For those of you who are more experienced at reading schematics, you might like to confirm my conclusions above::
http://users.tpg.com.au/adslljrb/22R...ng_diagram.pdf
PS. Wiring diagram provided for educational and research purposes only.
Peter
I've rescanned the 22R wiring diagrams in higher resolution (720 dpi) so if you have downloaded the pdf from the above post you might like to replace that file with these individual files. The single file above has some blank spots.
Here they are - all are Adobe PDF format
Starting, charging, ignition, carburettor and emission control systems [982Kb]
http://users.tpg.com.au/adslljrb/22R...r_ignition.pdf
Exterior lighting and horn [962Kb]
http://users.tpg.com.au/adslljrb/22R...r_lighting.pdf
Courtesy lamp, clock, cigarette lighter and sound system [743Kb]
http://users.tpg.com.au/adslljrb/22R...g_interior.pdf
Instrument cluster for models before August 1991 [903Kb]
http://users.tpg.com.au/adslljrb/22R...er_pre0891.pdf
Instrument cluster for models after August 1991 [612Kb]
http://users.tpg.com.au/adslljrb/22R...r_post0891.pdf
Ventilation system, air conditioning, demister and windscreen wiper and washer [719Kb]
http://users.tpg.com.au/adslljrb/22R...entilation.pdf
Automatic disconnecting differential (ADD) system, 4WD lamp and automatic transmission overdrive [739Kb]
http://users.tpg.com.au/adslljrb/22R...ng_ADD_4WD.pdf
