Results 1 to 15 of 23
Thread: how can you tell if its an lsd?
    Tradie Grease Monkey jcmunga's Avatar
    Default how can you tell if its an lsd?
    how do you know if you have an LSD hilux center without takin the center out of the housing?
    are there any differences in the center casing?
    any help would be greatly appreciated
    thanks
    Daily Driver: Holden Rodeo
    Under Construction: RA28
    Junior Member Conversion King deviant's Avatar
    wa
    Default Re: how can you tell if its an lsd?
    Is it on the car? If so just jack it up and turn one wheel...if the other one turns the same direction then you have an LSD..
    Or you could do a fully hektik skidzby pressing X and Square at the same time and see how many lines you leave behind
    Quote Originally Posted by S2K
    Would a VTEC limiter be a helpful device?
    Junior Member Backyard Mechanic SIKTOY's Avatar
    Quote Originally Posted by deviant
    but if it dosn't you might still have a LSD with warn clutch packs pull it out to be sure or look on the complience plate on the car it came out of
    Ben
    reputation is nothing knowledge is everything
    RA23 1GGTE 12.3@110mph
    1980 RA40 now getting a 1G with new picsLOOK
    Don't argue with an IDIOT.He will bring you down to his level and then beat you with experience!
    any markings on the housing say LSD oil only?....but you probably would have noticed that already...
    blake
    Quote Originally Posted by SIKTOY
    Ben
    hmm, its not in the car and i dont know what car it came from, the diff housing is from a RN25 and i was told the center was an LSD from a 95 hilux surf. iv just had them put together and the wheels dont turn the same way when one it turned
    lick the top of it and wait for abit
    if you start seeing funny things then its lsd
    heheeh
    after licking it, look in the filler/drain hole, see if you can see the pinion gears or not... perhaps....
    or pull the centre out and check...
    how can ya tell once the centers out? what do ya look for?
    Quote Originally Posted by jcmunga
    thanks
    Go to your engine bay and look on the compliance plate mounted on the firewall.
    There are numbers there for your gearbox and diff. If you have the original diff in your Lux then this will tell you if you have an LSD.
    If you have different numbers then download this document which has a table for checking what diff you have.
    http://users.tpg.com.au/adslljrb/Differentials.pdf
    Peter
    Quote Originally Posted by infotechplus
    Peter
    hehe, thanks but the car was crushed ages ago
    LOL, I should have realised. My bad for not thinking the obvious.
    Peter
    open diff
    in an LSD centre, it will look more like this, ie, can't see the pinion gear directly
    If you have the diff off the ground, and you turn one wheel and they don't both go that direction, i'd say its not a clutch type lsd.. even if its shagged 3 ways to sunday, it should still do it..
    no inspection plate or something? like oldie said, up the drain hole?
    Jun 2006
    If it is out of the car get someone to hold the pinion (where the tailshaft bolts on) turn one hub;
    If it not an LSd the other hub will turn backwards easily with little effort required to hold the pinion (if brakes aren't binding)
    If it is an LSD it will try to make the pinion turn and the other side hub will try turn the same way.
    regards
    jon
    while it's likley you don't have a torsen diff, they fail the jack it up and spin one wheel test.
    Jordan
