will it come out if you take the rear wheel off and slide it sideways so the back bit is beside the car then slide it out?
if not a 5inch will save the day
Hey guys!
okay ive taken off all the brackets and have taken off the inlet and exhaust manifold... how the hell do i get it out from under the car?
does it need to be cut where it goes over the diff so the front piece and the rear piece can come out? or is there some other way of getting it out?
Kenno
Green 1993 KZN130 Hilux Surf
Black 1977 RA28 ( Sold )
2008 DHZ 140cc pitbike
nah that wont work because all the suspension is in the way but thanks anyway...
i guess im just going to have to cut it off where it goes over the diff... because it is facing upwards, its easier when it comes to welding it back together...
cheers,
Kenno
You dont have to cut it. if you undo the rear shockie and jack the car up you will get a heap more suspension travel and that will allow you to get the exhaust over the diff
Im gonna rip out all of the rear suspension 2 see if it matches up with the RA40's...
Ill jack the rear up 2morrow and pull it all out....
Kenno
as dave says you have to really get the car on a ramp & take off the n/s shock to drop the backend down & then manouver the exhaust off its really tight but with a wee bit of pressure it comes off.Originally Posted by airfireman1
yeh the RA40 is up on ramps at the moment...
Ive undone the inlet and exhaust manifold and all the brackets...
Ive just gotta get it out...
I will undo the rear suspension 2morrow and see what happens...
Thanks guys
Kenno
