Results 1 to 15 of 15
Thread: o2 sensor...are they really needed, ??????
    Default o2 sensor...are they really needed, ??????
    hey guys, well im made up my dump pipe, and left out the 0'2 sensor, as some have advised me that they arent really needed, and hardly work, if at all on some cars,
    im a reall noob when it comes to this sorta stuff,
    are there any pros or cons to just leaving it un hooked?
    cheers, blake
    Default Re: o2 sensor...are they really needed, ??????
    if your ECU can do closed loop fuel control, you will save fuel during cruising/normal driving.
    if you have a shitty ECU that doesn't have closed loop, you will either use more fuel, or the ECU has to be tuned lean to not use as much.
    closed loop ftw!!
    O2 sensor is not used under load.
    Also good for monitoring.
    Quote Originally Posted by Screamn_Sleeka
    Not really.
    A narrow-band lamba sensor will only tell you rich/lean, you can't really do good tuning with them from monitoring.
    If all you want to see is rich/lean though then it'd be okay.
    Welcome to the Darkside! Automotive Encyclopaedia -==L=a=N=c=E==-'s Avatar
    Rosewood
    IN 05 NT: what ecu are you using?
    If it is a microleb or similar, it won't need the O2 sensor. If it is a ECU capable of closed loop (i.e. OEM ECU or some other better ECU's on the market) Then it would be a good idea if you want economy.
    If its going to be a full out race car. Then why are you worrying about economy or emissions for that matter
    Montrose
    Putting a bung in the pipe is still a good idea, so you can stick a wideband sensor in there for tuning etc.
    If you're using a factory ECU, then fit one.
    im just running stock ecu....atm,
    so theres no real harm in leaving it out, just that it may run a lil rich, thats cool with me,
    cheers fellas!
    T'ville, QLD
    ummm yeah ur gonna need it if the OEM ecu had one u need it, if its disconnected it will run so freakin rich cos i thinks its not getting a reading cos there aint enough fuel, u will use about 3 times the fuel maybe? i know i accidently disconnected the o2 on the pulsar while fixing an exhaust leak, and used up a whole tank after 150k's check engine light came on but i ignoreded it.... not a smart thing to do.
    but yeah put it in
    2T out 4A in....
    Show Us Your Tints Carport Converter Soarer_D00D's Avatar
    Even if you have left it out, its not one of those hard things to drill out, braze a collar on and screw one in later on if need be. I've got one in my dump pipe, but my 1J is controlled via a Wolf3D, so its kinda nessacery
    Quote Originally Posted by eeeyan View Post
    yeah jump start a planet sort of torque
    ahh cool, guess ill have to fit it them....something else to add to this arvos GROWING list, lol
    its not a screw in colar type, its a 2 bolt flange type,. so i gotta make a flange for it too,
    cheers fellas,
    Can't be that hard.
    T'ville, QLD
    lol atleast u dont have a distributor comming out the back of the head, thats a pain in the rectal oriface, a flange? pfff 20 mins work
    2T out 4A in....
    no but its fookin round that i honestly cbf, lol...its saturday....afer a late night friday, lol
    i'll get it done, got to rebuold the alternator now aswell, lol
    This is a Gen2 1GGTE ecu?
    You'll run stupidly rich and lose a lot of power if you don't run one.
    just thought id update you guys,
    fitted the o2 senso just now,.....it idles smoother, and blows alot less fuel out the zorst...lol
    cheers for all your help!.blake
  1. Jaycar DFA Help needed!
    By NeoNasty in forum Tech and Conversions
    Last Post: 29-07-2006, 12:27 PM
  2. 4AGZE to 4AGTE in AE86 Info needed
    Last Post: 17-06-2006, 11:15 AM
  3. how much oil is needed to fill a 1JZ
    By 53TUP in forum Tech and Conversions
    Last Post: 12-06-2006, 02:36 PM
