Hi mate that second picture has a Oil Temp Gauge with sender in it, can't you use that?
It is below the taco, speedo, fuel and to the right side of the Water temp ...
The second page!
Does anyone have access to, or know where I can get a copy of a 1973/1974 gtv TA22 wiring diagram from?
This thread has the diagram I have now which is suitable for ET/LT/ST, but am after one with the oil temperature gauge as reatured in the gtv TA22s.
http://www.toymods.net/forums/showth...wiring+diagram
The second page!
heh..............that'll teach me to look past the first pageOriginally Posted by Rosey
I was also interested in the gtv or even gt diagram as the long console I have has a switch in it I believe is for the power antenna.
Also the wiring for the JDM tail lights which were slightly different to Aus delivered LT tail lights. The JDM ones have an extra globe in them as extra rear hazard lights.
Hi on my ta22 the electric ariel went up when you switched on the radio & down when switched off, useless piece of info.
74GT,Originally Posted by 74gt
Switch on the long console (beside the handbrake) is for a power antenna. The switch itself has 3 connections; power to the switch and 2 power feeds (for antenna Up or Down).
The factory power antenna has an earth switching relay on it to change polarity on the antenna motor depending on wether Up or Down is selected. To get an aftermarket antenna (semi automatic type) to run off the original switch you will need to put a couple of relays into the antenna power feed system to be able to switch earth and hence the polarity on the antenna motor.
Or alternatively use the switch which comes with the antenna and hide it under the console ash tray lid.
If you have a modern radio with an antenna power feed all you need is a fully automatic power antenna but you do not get the joy of playing with the console switch.
The extra globe in each of the rear lights (front corners also although just an extra fillament in the bulb) is powered via the JDM 3 way hazard switch. These are not extra hazard lights, just low power parking lights. Can be selected from the JDM hazard switch as left side only, right side only or both sides.
You will find that all models are pre wired at the front end to run these lights (unused connector in the indicataor/side light harness bundle at each side). You do need the JDM front corner light units to make them work.
As for the rear lights you need to get the appropriate power feed from the JDM hazard switch to the rear lamps. ST and GT export models have the required dash wiring although unused. LT models do not. The standard export body harness has 2 to few wires on it. A simple fix is to use 2 wires of the 3 stereo speaker wires which form part of the body harness. Put in a connector behind the rear seat then install connecting wire back to each of the rear lights.
This goes for the non flat light models. Rear wiring, including for the low power parking globes, on the all red JDM flat light rear lamps is a whole different ball game.
Clear as mud!!!!!!!
Sid,Originally Posted by sidta23
That sounds like an aftermarket arial with a modern radio... if it indeed is OEM equipment though, this could be an interesting quirk.
