Results 1 to 4 of 4
Thread: 6-speed GB for 20valve FWD?!
    dirty Grease Monkey Roof87's Avatar
    May 2006
    Default 6-speed GB for 20valve FWD?!
    Hows things fellas...
    Can somone point me out the right direction in regards to finding one of these 6-speed gearboxes which suits FWD corolla AE92, im in syd and cannot find one. Does anyone know more info about these i think its a C160 or along the lines of that, but i can't be certain, im definatley a gear box n00b. If anyone knows please share your thoughts and advice.
    Cheers.
    Roof.
    Default Re: 6-speed GB for 20valve FWD?!
    did u call all of the engine importers?
    May 2006
    Thumbs up Re: 6-speed GB for 20valve FWD?!
    Rob,
    Thanks for replying, yeah i did try a few in syd, such as just japs, sss automotives - one tells me its from a MR2 and another bloke tells me its from a lexus, both have none in stock and haven't had any in stock for some time.
    I thought a few people here would have some idea and thought i would get a quick and easy reponse, after all this is a 'friendly environment where we learn to modify our cars'.....right?
    you'd be after a C160 from an AE111 Trueno or Levin, usually in the BZ-R and in another model I can't recall at the moment.
    Looks just like the 5-speed apart from the end case is a bit longer to accomodate the extra gear. It didn't come out in the MR2.
    The ZZ celica's and ZZE123 corolla sportivo's also use C series 6-speeds which you can swap your 5-speed front casing onto in order to make it compatible with an A series motor. There's info on this swap at www.mr2oc.com in the MKI section from memory. It's a fair bit of work, but possible if you're determined.
    Jason
  1. KE 35 conversion from 2 to 3 speed (auto)
    By woody012 in forum Tech and Conversions
    Last Post: 02-01-2006, 10:12 PM
