So it is possible to swap in 3s crank into 5s block ? I havent seen this before but this would be great not too keen on a longer stroke but over square would be cool.Originally Posted by Joshstix
The machining and engineering/balancing in them is just a touch better than those in off the shelf street engines...Originally Posted by Ben Wilson
Top end $1500+ each speakers use paper cones... and so do $10 cheapies... so why do people by the mid range $150 polypropelyne ones when the best use paper cones?? Surely a paper cone is a paper cone, just like rockers are rockers??
Please note the use of sarcasm in the analogy
Yep definately possible. Personally I'd go for the extra capacity though. There are people running 3S/5S strokers to 8500-9000rpm quite regularly these days so I don't think it would be too much of a problem. The other thing is when you get the 5S crank turned down to run 3S rods you can get a larger fillet radius machined into it since this is the weakest part of the 3S crank.
Nup, you are getting your bits confused. Solid lifters replace hydraluic lifters. hydraulic lifters pump up to clearance whereas solids are just that 'solid', and thus are clearanced somewhat like shims i imagine.Originally Posted by 4agte
3S-GTE limit is 7.21 seconds![]()
http://microtechefi.com/microtech-ra...hp?champ_id=18
Originally Posted by skiddz
TOP SECRET Toyota Supra (JZA80)
Engine: 3SGTE 2.2L
Output: 720ps/8500rpm
300km/h New Zealand High Speed run
S.M.R
There is a method in the madness
the old BMW 1.5L 4Cylinder F1 motors. got your 1.5Mw of power from the 80'sOriginally Posted by 4agte
it's horn
then they were banned in competition
Or for someting you could actually buy with a warrenty the BDTE 2.1L motor takes the cake. Out of the Ford RS200 Evo. 650HP out of the box, mid mount, 4WD, 0-100km/h in 2.1s all housed in some scafolding and Carbon Kevlar weighing in around a tonne.
Then they were banned
for NA it has to be the 8V per piston Honda 4stroke with oval pistons from the late 70's (that took them over 13 years to finally figure out it was a good idea but technically impossible) that was set to take on the 500cc 2strokes. pity the piston rings kept failing,
and then they were banned.
as for a production easily obtainable motor:
Turbo it's the Delta's motor-Cosworth YBT-FJ20
NA it's FC20-Cosworth anyting (BD and YB series)-4AG big port-Honda B-series
Jordan
Jordan
Put simply, the best 4cyl is the one that goes the hardest, is the most reliable, has decent aftermarket support...AND costs you 2/3 of sweet fuck all to acquire and maintain!![]()
Whether or not this is a 3S i cannot say, but my Gen 3 has been good to me and thats all i can ask of it...
Tim // Melbourne, Australia
1986 ST165. with ST205 WRC engine / IC system / rear LSD
Apexi Power FC
Blitz K1-380V Turbo with full 3" Aussie system
Ogura 409D Clutch Kit
TWM short shifter, Whiteline front strut brace
ahh nice i get it cheers + repOriginally Posted by JustenGT8
yup agree awesome engine over 1100hp possibly even 1300 odd hp in qualifying and lasted for.........Originally Posted by jfallen
Its easier to make big hp with boosted motors tho... the fact a 2ltr 4 n/a can make 240hp and reliably spin to 9k is awesome it wasnt that long ago that holden v8's were making less power with 5 ltrs
st215 gen 4 3s are not vvti! I own one, the st245 are vvti and sadly all auto and heavier than the st215. Gen 4's also were released from factory with the highest figures of the 3s being 195kw (flywheel). Yes the manifold and exhaust housing are cast as one on the gen 4's and are not backwards compatible to the gen3 (not that you would want too!) Aftermarket exhaust manifold = win![]()
Previous ride ST215 Caldina GT-T
Screamer pipes, quiet when you want them to be and loud when you wanna gate old ladies at the bus stop...
Thread revival much?
Hi there. I see that you people never mention 1gen 3sg engines, are they not good engines or just hard to find.
I have one waiting to live in the hood of my TA22 yoda.
thats because theyre pretty scarce now and don't make the kind of power gen 3's and above do. they only came in ST165 GT4's anyway.. so they're an ageing breed.
JZZ20 1988 Soarer GT Twin Turbo 1JZ-GTE + R154 + LSD | Black Knight Still being Assembled
