The 2JZ is about 25mm taller than the 1JZ, but otherwise dimensions are identical.
A/C compressor is on the passenger side so you won't have any clearance problems with steering components.
With the stock sequential turbo setup you'll have strong boost before 2000rpm. Lag is not an issue with this engine.
1j's are a hella tight fit.. but they do fit.. (in a YN57) im not sure a 2j would fit with the stocko twin turbo setup..
