I can confirm this can be done properly as well. I'm currently building a G-series for someone that was originally a 6 stud to 4x114.3. It's not exactly cheap to do, but it's definately worth doing properly. I've seen a terribly re-drilled axle with the studs re-welded into the hub due to a slotted hole. FWIW, the guy that does my axles has no problems engineering all his work and he's done HEAPS of these now.Originally Posted by Dimitri
I'm also using a simliar setup to slutty using r31 gear. Aside from the caliper adaptor bracket, the only other thing needed are new handbrake cables to suit.
Eddie.
4agte finally completed. 234rwkw @ 8125rpm. Tis fun
