it is a bit quiet isnt it.
clean as much crap off the top ot the engine as you can, then remove the panel between the cam covers.
give the "valley" a good blow out with an air gun to remove whatever is in there.
some people loosen off the plugs and turn the engine over (with high tension lead removed so it wont star), which blows air out the threads, but i;m not so sure this is a good idea, as it would suck in also.
loosen off the plugs and give it another blow out.
i'd only replace them with platinum plugs, i checked mine a few years ago, saw they were platinum then just put them back in.
i wouldnt change leads unless you are having issues (same as plugs)
