might or might not be relevant but the dizzy on them could be a hassle (4 cylinder 2200cc engines).. would cause the "sometimes it starts sometimes it won't" issue..
normally turning the key to ON, it only takes a second for the fuel pump to prime up the lines, then it stops until u start up so i'd doubt if hearing the pump is an issue or not.. considering the pump is new, either investigate it being installed incorrectly or has come to any sort of "failure" which i hope u've still got warranty on them, and sort the pump out, otherwise next bet is the dizzy (which also points to your symptoms of low power uphill etc etc)
