Results 1 to 8 of 8
Thread: Hiace vs Hilux vs Supra centres.
    Default Hiace vs Hilux vs Supra centres.
    Hi all
    I have my hilux off the road whilst doing the engine conversion..I dont particularly want to take the diff out of it yet as id like to have it there to work out my tailshaft length etc.
    the goal of what i am doing is to put a ma70 LSD and gearset into the hilux diff. I also have a hiace diff lying around which i can pull the centre out of....
    Just wanting to know, if i take the hiace centre out, and put the ma70 lsd and gearset into that centre ( i know a shim has to be made - will take it to diff shop.) will it bolt straight into the hilux diff?
    thanks all
    Blake
    Dreamer Backyard Mechanic millsi's Avatar
    Default Re: Hiace vs Hilux vs Supra centres.
    im hoping it will as im about to do this, as you said i will need to get a new crush collar to pre load the pinion bearing.
    pulled the ma70 lsd centre out today (what fun).
    wa
    not trying to hijack your thread but just wondering if you can bolt a cressida diff straight into a hilux with the lsd centre and if the axle splines are the same
    Welcome to the Darkside! Automotive Encyclopaedia -==L=a=N=c=E==-'s Avatar
    Rosewood
    As long as its G Series it should just about bolt on. Some variances in bearing sizes etc are different.
    I've got a MA70LSD in my hilux diff. Wasn't done by me personally, but at the mechanics. Bolted straight in.
    Rosewood
    Hilux carrier with LSD.
    so i take it it should work then using the hiace centre?
    Quote Originally Posted by -==L=a=N=c=E==-
    all i can say is it definetly isnt a bolt in affair after seeing the two side by side today! did they charge u a lot?
    Rosewood
    Quote Originally Posted by Robbos_Toyotas
    The price of the centre, refurbish the lsd, and bolt it all together. Not really.
  1. hilux to supra diff centre interchangability???
    By millsi in forum Tech and Conversions
    Last Post: 17-11-2006, 07:04 PM
  2. changing the gear ratio's in hilux diff.
    Last Post: 14-10-2006, 12:41 PM
  3. Hiace and Hilux conversions
    By Robbos_Toyotas in forum Tech and Conversions
    Last Post: 30-06-2006, 08:35 AM
